Wierd Charging Problem
Old May 26, 2015 | 11:13 AM
LDB C5's Avatar
LDB C5
Default Wierd Charging Problem
I am having a very strange issue with the charging system on my 66. The alternator is 85 amp replacement, externally regulated. The engine is new, as is the rest of the drive train. After completing the engine swap everything was fine for about 2 weeks. Then the wierdness started. The system was OVERCHARGING. Amp gage read +30 - +40. Voltage at the battery was 15.0.
Replaced Voltage Regulator and Condenser, and there was some improvement, but the system is still acting funny. At idle (~850 rpm), it will again overcharge (+ 20 - +30 on the gage) the headlights get brighter etc. Over ~ 1000 rpm everything looks normal.
Any ideas?
Old May 26, 2015 | 11:33 AM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
Well, hmmmmm..... are you sure the regulator is well matched to the high output alternator? If so, and since changing the regulator didn't help, I'd be suspicious of the alternator. There really isn't anything else.
Old May 26, 2015 | 11:41 AM
LDB C5's Avatar
LDB C5
The regulator did help albeit incrementally. Why would the system overcharge at idle and perform as designed at anything over ~ 1000 rpm?
Old May 26, 2015 | 12:40 PM
LB66383's Avatar
LB66383
The only thing in the system that is RPM-dependent is the alternator. Everything else is just electrons. Since it was OK for a couple of weeks, I'd say something has gone in the alternator. Probably one or more diodes. My uneducated guess is that the system is seeing more of an AC wave than pure DC, and as the RPM/frequency increases, it is smoothing out -- becoming less of a fluctuation .
Old May 26, 2015 | 12:58 PM
jim lockwood
Don't know and does it really matter?
The charging system isn't working properly. There are only two major components and changing one of them didn't solve the problem. Time to do something about the other one.
Old May 26, 2015 | 08:30 PM
plaidside's Avatar
plaidside
Here is a couple of things I would try.
I have found that on all external regulators, except Chrysler electronic ones, that a poor ground will create an overcharging condition.
First run a temporary ground wire from the batt - to the frame of the regulator and test.
I would also check the voltage at the Batt post of the alternator, the battery +, the #3 red wire at the regulator plug and the Batt lug of the horn relay when the engine is running.
Write these readings down and post them.
Joe
Old Jun 2, 2015 | 11:49 AM
LDB C5's Avatar
LDB C5
Additional ground wire didn't change anything. Voltage at the BAT terminal on the alternator, at the Battery, horn relay and sense terminal at the regulator are all the same.
at ~ 850 RPM ~ 17.5 v
at ~ 950 RPM ~ 15.5 v
at ~ 1000 RPM or over all appears normal @ 14.2V
Old Jun 2, 2015 | 02:04 PM
dplotkin's Avatar
dplotkin
2015 C2 of the Year Finalist
Good guess, I agree.
Take your DVM, set it to AC volts and measure across the battery. If it reads 300 millivolts or higher, you have one or more failed diodes.
Dan
Old Jun 2, 2015 | 02:22 PM
LDB C5's Avatar
LDB C5
Seeing ~30 VAC across the battery; Bad Alternator?
Old Jun 2, 2015 | 02:53 PM
dplotkin's Avatar
dplotkin
Absolutely. Bring it back.
Dan
Old Jun 2, 2015 | 03:18 PM
426 Hemi's Avatar
426 Hemi
Had an overcharging/high voltage problem on my '65 Chevelle. Went through a couple regulators----still overcharged. Long story short----the alternator had a new stator. When they crimped on the terminal lugs they failed to remove the enamel from one of the solid wires. Kept making/breaking contact. Freaked out the regulator to force it to full charge. Replace the stator and all is well.
Old Jun 2, 2015 | 03:22 PM
LDB C5's Avatar
LDB C5
The Alternator is a Power Master 65 amp that I had ordered through Summit Racing (April of this year) I just got off of the telephone with customer service. They are shipping a replacement under warranty today! With a little luck, should be back up and running tomorrow!
Old Jun 2, 2015 | 03:50 PM
65silververt's Avatar
65silververt
Not sure if this has been suggested, but check your main lead wire where it connects to the alternator. It is common for the nut to be overtightened and the plastic surround to crack, causing a short. I just had this problem with the power master alternator in my 67 Restomod convertible. It was putting out 16Volts to the battery. I sent it back to power master and they rebuilt it for around half the cost of a new one and upgraded it for free to a 240amp to help power my electric fans and electric fuel pump.
I see you said they are sending a replacement. That's great, but check the surround anyway to see if it is cracked and be careful not to over-tighten the nut on the new unit.
Old Jun 2, 2015 | 03:58 PM
LDB C5's Avatar
LDB C5
Just want to say THANK YOU to everyone that offered assistance / advice!
I will check the post, and be careful with the replacement. I will also try to post the end result.
Old Jun 2, 2015 | 04:42 PM
dplotkin's Avatar
dplotkin
Gentlemen: the man's alternator is producing 30 volts AC. That is not a stator problem or a output lug bushing problem. It is a rectifier problem. Alternators do not produce AC current at its output unless defective.
Dan
Old Jun 2, 2015 | 05:41 PM
LDB C5's Avatar
LDB C5
Dan
UPDATE !!!
As I mentioned, Summit is replacing the alternator. Just for giggles, I swapped it out for the old alternator (35 amp) that was in the car when I bought it 6 years ago. The old unit was working with no issues when I did the engine swap, I only changed it because it looked like azz with the new engine!
Guess what .............................. Same exact issue! 15 - 17 VDC at the battery at anything below ~1000 RPM; 14.5 (ish) VDC at the battery at anything over 1000 RPM. When I checked the VAC at the battery I get 30.1 - 32.5 VAC at any RPM.
2 bad alternators ?!?!
Old Jun 2, 2015 | 07:07 PM
jim lockwood
Are you sure you are measuring 30 Volts AC at the battery???? Or could it be 30 mV (.03 Volts)?
I'm just skeptical that you could get 30 Volts across the battery because the battery represents a very low impedance load. Your alternator would have to be dumping hundreds of Amps into the battery to do that.
To Wierd Charging Problem
Old Jun 2, 2015 | 07:49 PM
65silververt
Wouldn't that much voltage be cooking the battery?
Old Jun 2, 2015 | 08:26 PM
LDB C5's Avatar
LDB C5
The voltmeter is reading 30.1. Next question is is the DVM good? There are only 2 scales for VAC. 600 & 200, but it doesn't specify VOLTS or mV.
Old Jun 2, 2015 | 09:46 PM
jim lockwood
Any chance you could post a picture of the DVM screen at the moment it's indicating 30 somethings?
Jim
