327 375 hp pistons
Most have had some moderization tweeks directly to them
related to the combustion chambers and other areas of the pistons! if you want more traditional to the period, I wouldn't go back to the special outfits- but go back with like TRW units (or other OEM type suppliers) if that is what you are wanting.
327 375 hp pistons
Thanks for the info will check into it
Received 1,861 Likes
Here's the Federal-Mogul/Speed-Pro L2166NF forged piston - absolutely identical to the factory TRW part (except for the added anti-friction coating). Second photo is an original.
Is this the same piston as a 1972 350 LT1?
Received 6,741 Likes
C2 of Year Finalist (track prepared) 2019
Alot of the high end piston guys
seem to have a formula of offerings based on study of what they think there is a market for that actually goes with the compressions and bores that most guys would need or want. I have shopped for pistons and the last ones were like space ship leveled spec'd out by Ross for me with all of the bells and whistles and free T-shirt, but that custom stuff causes me to eat Top Ramen for the next week or so based on the cost. and yet again, because of getting car parts for the millionth time, i forgone getting my first tattoo that was planned in my military days originally. So i have car parts, eating top ramen and still not actually tattood!
1970 Z28 Engine - LT1 360hp (gross)
Domed type - yields 11.0:1 compression
63.995 cc, 2.02/1.6 valves, screw in studs & guide plates
1971 Z28 Engine - LT1 330hp (gross, 275hp NET)
Flat w/valve relief - yields 9.0:1 compression
75.47 cc, 2.02/1.6 valves, screw in studs & guide plates
1972 Z28 Engine - LT1 255hp (net)
76.18 cc, 2.02/1.6 valves, screw in studs & guide plates
Reason I asked is I have a 1972 CE 350 LT1 & angle plug 2.02/1.60 heads that I think are 64cc. The pistons are domed so I'm guessing this replacement engine is of the 1970 LT1 360hp family.
I have a CE 512 block with the rear vent PCV hole, both the 512 and LT1 010 are low mileage Std. bore blocks. My plan is to use the crank, rods and pistons out of the LT1 block and build up a 350 that is dressed out to look like a 327/350hp. I am concerned about the compression using these pistons and the 461 heads 64cc heads.
