1963 corvette ignition switch problem NEED HELP!!
Old May 31, 2015 | 02:10 PM
19sleepy65's Avatar
19sleepy65
Default 1963 corvette ignition switch problem NEED HELP!!
Has anyone had the problem of the key pulling in out in the "on" position? and if so have you found a fix? The 63 judging manual says it should not pull out in the on position, any help would greatly be appreciated!!
Frank
Old May 31, 2015 | 03:55 PM
JohnZ's Avatar
JohnZ
Frank
That's a worn key, or worn key cylinder/tumbler, or both.
