Overheating
Old Jun 2, 2015 | 05:46 PM
Gary's '66's Avatar
Gary's '66
Guess you don't wish to address the possibility of plugged water jackets, huh?
Gary
Old Jun 2, 2015 | 06:23 PM
LDB C5's Avatar
LDB C5
My Money is on the combination of higher ambient temps combined with the stuck thermostat
Just a side note; dont put any thread sealer or Teflon tape on the sending unit. It gets it ground through the threads.
Old Jun 2, 2015 | 08:03 PM
JohnZ's Avatar
JohnZ
Doesn't matter - that's another "internet legend" - the sharp pipe thread form will cut through any sealant with no effort at all, and even if it doesn't and resistance is increased as a result, that would make the gauge read lower, not higher. Read the paper below to see the testing done by this forum to address this issue.
Old Jun 3, 2015 | 09:50 PM
JLSmith's Avatar
JLSmith
Success! A new 180* t-stat did the trick. 97* here today and the car never got above 185* measured with an IR gun. I also learned that my dashboard temp gauge indicates 180* at the first mark - A good thing to know. Thank you to everyone for your suggestions and help.
Kurtibm, thank you for the lower radiator seal. I'll be putting it to good use.
- Jeff
Old Jun 3, 2015 | 11:26 PM
C2Racer's Avatar
C2Racer
That's a good day, congrats! Pretty easy fix too. Now you're ready for Summer fun......
Steve
Old Jun 4, 2015 | 01:42 AM
John S 1961's Avatar
John S 1961
230 is too hot 220 is ok, generally it should be at t stat temp except in 100 plus ambient
