Engine Problem, What's Wrong
I remember my dad had a oil can filled with transmission fluid and he would squirt oil at the edge of the intake while the engine was running. When there was noticeable smooth out of engine rpm, and he could see where the oil was being sucked in, there was the leak. Hate the thought of doing that on my new Edelbrock alum. Manifold!
Like I said, worked great for me, cost me nothing.
Good luck with it
I got tired messing with this old carb so this morning ordered a new one from Summit. Supposed to be here tomorrow.
Expecting great things...
you must be messing with us
It sounds like you are now in the "throw parts at it until it is fixed" mode.
Good luck with your car.
Really the best deal on the planet is to have lars rebuild a good core qjet and he will test run it in for u also so u know its in tune. Well it sounds like u bought a remaining stock new Edelbrock qjet from summit and should be in good hands.
Hope things work out with the new carb.
Not sure I don't want to go back to my original intake & CalCustom valve covers with breathers and say to hell with it!
Anyway, it idles fine now with the rebuilt carb. I reset the timing at 8 deg. and test drove it. After a few blocks, it acted like it was missing and I think it is the PCV. Tomorrow I will test drive it again without a PCV and see what happens. Thanks to all for your help and guidance.
You say it does not idle. But does it seem to run smoothly above about 1500 rpm?
Have you confirmed the timing, sounds like you have.
I would eliminate the question of vacuum leaks, since there is a tie to the valve cover, intake, and carb swap.
Like Franks says, get an UNLIT propane torch (the kind used to braze copper piping). First turn it on (did I mention unlit?), and point it down the carb primary throat, and listen to the engine speeding up - it's burning propane with the carb gas.
Now slowly pass the torch end, unlit, over the body of the carb, the carb to intake gasket interface, all hoses and fittings associated with the PCV system, and the intake to head interface. If the engine speeds up, you have pinpointed your leak. This method will reveal leaks too small to otherwise be seen, including hard to reach and see areas. If it does not speed up, you have eliminated any leaks (the only oddball being the area of the intake to head interface that is open to the valley; however, any leaks here will result in a suction, instead of a slight pressure in your crankcase, which the propane torch should reveal when you expose it to the PCV system). Did I mention the torch should be used unlit?
Also, I installed the Corvette script valve covers using the new FelPro Dry gaskets. One side sealed well but the other side leaks like a sieve. Is it feasible to fix this with red silicone adhesive?
Valve cover gaskets leak over the top where oil is splashed...that is where they must seal.... Regular cork FelPro with ultra-gray RTV where the cover meets the gasket is all I ever use - leak free...
I guess I won't even ask why you swapped out good parts on an engine you yourself state was running great
So, I started cleaning it up. Removed and painted the wiper motor, hood hinges, firewall, fender wells, had the splash shields powder coated. Painted the exhaust manifolds gray & engine orange.
As you know, in order to use Corvette script valve covers you have to have a manifold with the fill tube. I wanted to keep the quadrajet (my preference) so I could either use a cast iron or aluminum manifold. The Performer 2101 had provisions for the fill tube, could drill it for a rear PCV, looks kinda like the 2x4 setup, and drops a lot of weight off the engine.
Fixing our cars or making them look or perform better while keeping a stock look is what it's all about, right?
Before
Almost done
I would sure like to know more about this PCV valve you mention. Anybody have a part # for this?
Intake w/PCV
