I'll be changing my generator to a one wire alternator. I've got the needed brackets, but my question is do I go directly to the battery, or the red primary wire coming off the voltage regulator. I know I have to abandon the voltage wiring. Please help.
St. Jude Donor '04-'05-'06-'07-'08-'09-'10, '14-'15
I put a Ramjet (EFI) crate engine and Vintage Air in a 62 Corvette and used a 90 or 100 amp one wire alternator.
Drove it a lot and never had a problem.
Very Popular with Hod rodders who have limited Accessories. But has no way of sensing loads like A/c Headlights and other current draining items. If Your load is heavy then your fine
Will work fine except when it is charging the battery at full Bore with out a heavy load is Sort like water torture..More then needed which makes for a shorten life and water consumption in the battery.
Here's one I did Form the Mad man...What a difference in brightness in low beams and High Beams..A little work but those Rice Burners got nothing on me..No more Yellow dim Head Lights..
Alot to read but you will see that a one wire for your car is not the best way to go.
What the link says is that the 3 wire voltage regulator measures voltage after the main junction instead of at the alternator. So when you flip on your headlights the 3 wire will kick up the voltage to maintain 14 volts with the headlights on.
True and, IMHO, it's much ado about very little.
Real remote-sense power supplies have four wires:
V+
V-
V+sense
V-sense
To get remote regulation, you connect V+sense to V+ at the load and, obviously V-sense to V- also at the load.
In an automotive context, V- would connect to chassis ground as would V-sense.
The 3 wire alternators have only one sense wire, V+sense and the load is distributed throughout the car, so it can't possibly provide accurate remote sensing. Your best regulation, which is far from perfect, will be at whatever point the V+sense wire is connected. Regulation everywhere else will be poorer.
Your best bet, regardless of what type of alternator you select is to run large enough conductors that the Voltage drop between the alternator and the load is minimal.
V+
V-
V+sense
V-sense
Jim
My 65 Ratwagon is wired as shown by Mad Electrical Using the Horn Relay bus terminal which is the center of the electrical universe in the Midyerar Corvette Where all the power is sent out to run what needs to be run.
I use a Power master 140 Amp Alternator with an internal Voltage regulator. The sense + wire is connected at the Horn Bus terminal where one leg of the Dash Battery gauge is connected.
Since my Vette has dual electric Spal Fans and A/C with a Electric clutch as well as other added accessories The alternator does a great job keeping everything in check.
This is not brain surgery, but a Viable working system. I have an Under hood digital Voltage Meter which shows me what goes on when loads are applied to the system.
I can see that the 3 wire keeps up with the changing loads as they are applied and then removed.
Never had a problem running everything at once. So to me it makes sense. As a Friend once told me... "It's your Corvette..Do what you want with It."
