1967 Stalling
I am hoping the experts here could help with a problem that my Dad is having with his 1961 Corvette. It has the carbureted 283 ci engine. It stalls while idling and it also stalls when accelerating from a stop. You have to really give it a lot of gas while accelerating from a stop or it will stall. However, once cruising or accelerating at speed it runs fine. We've taking it to a well regarded mechanic who says everything seems to be adjusted correctly.
Thanks for your ideas!
What engine - 250hp? 300hp? Fuelie?
What transmission - Powerglide, 4-speed, 3-speed?
Are the carburetor and distributor stock, or modified?
Got a picture or two of the underhood area?
The title you applied says '67, but the post says '61 - which is it?
Dennis
Engine is the 283 ci with the 2 4bbl's, I believe it is 270 hp.
Transmission is the 4 speed.
Carburetor and distributor are stock.
I've attached a picture of the engine.
