'63 lube fittings
'63 lube fittings
I have a '63 SWC with power steering and can count 11 lube fittings..... am I missing any? Also, appreciate a lube diagram as I don't see any in my shop manual. Thanks, begee22
Received 6,946 Likes
2015 C2 of Year Finalist
It's in the first section of your GM shop manual. I also believe it's your owners manual. There is 3 or 4 on the steering linkage 4 ball joints and one on the the clutch cross shaft if a manual.
Received 1,843 Likes
Also wondering why they didn't make my '63 hardtop a split? Seems like they wanted to give the public a choice?
I've taken the hint. I try to refrain from the SWC moniker in posts where the coupe vs convertible discussion isn't relevant. Seems to rankle some.
But I do backslide occasionally....I'm a work in progress...
Just because you can doesn't mean you should
