Hi i have a Hurst Comp Plus shifter i want to mount to my 61 vette using a original style 61 corvette bolt on handle i dont know for sure if it will work for my car i had a mr gasket super shifter on before it worked fine but was to tall and i could not covert it to use the handle that i was told i could so i bought a used Comp plus that works how ever i don't know if all com plus's are the same and i need a new mounting bracket as the old Mr gasket won't mounting bracket only lines up with the center hole but not the other 2 holes i found one on ebay that is below want to know if it will work and if my old linkage that worked on the other shifter will work also Thanks Roger HURST 4 SPEED MOUNTING PLATE GM MUNCIE M21 M22 Borg Warner T-10 1957773
Roger,
I'm not trying to be unkind, but I'd like to suggest punctuation. I've read yours through 4 times, and am still not quite sure what you are asking/saying.
This belongs on the "C1 & C2 Corvettes" section. But the answer is below. I am sure Vettebuyer will fix it.
There are many different Comp + style base shifters. You do not say what 4-speed you are using. The correct mounting plate is the one you listed if you have the correct base shifter. The mounting plate may need some modifying to clear the rear of the tail shaft extension. I doubt any Mr. Gasket parts will carry over. If your transmission is a T-10, install kit is # 3733157. If it a Muncie, the arms will be different. I have those part numbers. Jim
Recent install in a 61 vette race car, M23 modified, new Hurst
Thanks for the nice picture mine looks a lot like the picture. Is there any differences in the comp plus i need to know about? are you talking about a 4 speed number stamp? on the side of the shifter? thanks Roger
There is no 4 speed number stamp on the shifter body visible. The shifter body is #3917535. The number on the stick is only for the stick, #7238. You still have not said what 4 speed you have. There is difference in the arms. Most popular transmissions are:
T-10
early Muncie (stud and nut)
Later Mumice (bolt)
Other
Jim
Mine is the T-10 stock original (1961 Corvette)) i am wanting to mount a comp plus shifter on to this i had a mr gasket super shifter on it when i bought the car. the bracket will not work i think the linkage may i hope. I have ordered the correct hurst mounting bracket so thats where i am at on this i just need to know if all comp plus shifters are generally adaptable other than the linkage and the handles Thanks Roger
Mine is the T-10 stock original (1961 Corvette)) i just need to know if all comp plus shifters are generally adaptable other than the linkage and the handles Thanks Roger
If your shifter looks like the one in the picture below, you are good to go. If you need the rods and arms and hardware, the Hurst installation kit is #3733157 for a t-10 trans. Jim
[QUOTE=vetrod62;1589983681]If your shifter looks like the one in the picture below, you are good to go. If you need the rods and arms and hardware, the Hurst installation kit is #3733157 for a t-10 transmission
Thanks so much the only difference i can see is the handle i bought the bolt on original style handle sure hope the linkage will work will save me about 200 buckes
That install kit complete with adpt plate, arms, levers, everything is $176.25 from Jegs. Chip
