LED Tailights
Old Jul 16, 2015 | 10:53 AM
keith.walker's Avatar
keith.walker
Default LED Tailights
I have a 65 convertible, 327. My taillights are very dim and I want to replace them with LED's. Do I need to install a new flasher also? Thanks for your help.
Old Jul 16, 2015 | 11:02 AM
SLWRNU's Avatar
SLWRNU
2026 Restomod of the Year Finalist
If you just change the taillights, no, but if you change the parking lights, yes you will need to install an electronic flasher. Real easy.
Old Jul 16, 2015 | 11:17 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
Sometimes....if the remaining lights (parking lights in this case) have enough internal resistance to allow the old mechanical flasher to work you are good to go. Sometimes its not enough so the flasher is inoperative....meaning you'll need an electronic flasher. Many of these items are reversed polarity from what the Corvette terminals require. You can use some short jumpers to 'flip' the wires or buy a small adapter and then things will work just fine!
Old Jul 16, 2015 | 11:35 AM
keith.walker
Thanks guys. It's no big deal to switch out the flasher. Should I just do it or should I replace the parking lights and the flasher?
Old Jul 16, 2015 | 11:45 AM
Frankie the Fink
Army
I've done all four corners with LED lights and an electronic flasher on both of my cars. I like people to know what I'm intending to do from the front or the rear; so brightness counts.
Put a little dielectric grease on the LED socket extensions when you install them and you'll have a setup you won't have to worry about for years....
Old Jul 16, 2015 | 03:38 PM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
What LED lights did you use?
Old Jul 16, 2015 | 10:52 PM
gator79's Avatar
gator79
I used these http://www.ebay.com/itm/CORVETTE-61-62-63-64-65-66-67-LED-TAIL-LIGHT-ASSEMBLY-BRIGHTER-SAFER-QUICKER-/191632412248?hash=item2c9e2e8e58&vxp=mtr really bright. this is just the tail lights on.
I also replaced the license light with a led strip light
Old Jul 17, 2015 | 08:06 AM
Frankie the Fink
Army
That is my source as well (the seller is a forum member)....
I used LED lights for my license plate light in both my cars and the map light in the 61 too....they run cooler and keep from turning the plastic lens covers into crispy, brown potato chips due to heat....
Again, ohiovet can fix you up with whatever you need -- LED bulbs, flashers, what-have-you.
Old Jul 17, 2015 | 10:48 AM
plaidside's Avatar
plaidside
I put LED's in both my 61's. The one in the video I only did the rear lights and I used a Standard EFL1 electronic flasher. You can hear it over the exhaust and car noise.
The other car I put the LED's in front and rear and I had to use a different electronic flasher similar to Frankie's.
Joe
Old Jul 17, 2015 | 11:03 AM
Frankie the Fink
Army
I think that video brings home what a great safety upgrade these LED lights are. My #1 fear when driving is idiotic, distracted drivers and a low-slung sports car can easily escape attention.
I run the LEDs and pump my brakes when sitting at stop lights when I see some moron zooming up behind me in my rear view mirror
Old Jul 17, 2015 | 12:09 PM
tuxnharley's Avatar
tuxnharley
You guys have convinced me I need to make this mod on my '67!
PS - I love his ad - "chrome housing and car not included"
Old Jul 18, 2015 | 02:38 AM
devildog's Avatar
devildog
From: fighter pilots make movies, bomber pilots make history
I installed LED on my 61, they only had two bulbs in stock. So, I took those and installed the two on the inboard sockets. I got a neat benefit.
The turn signals are sequential like an old T-Bird ! I just left it like that and get many questions "how did you do that ?"
Joe
Old Jul 18, 2015 | 06:09 AM
Frankie the Fink
Army
webelectricproducts STS-2 'juice can' sequential flashers will work for the rear of a C1 just as Devildog's 'unexpected benefit'.... I use them... They also make the brake lights come on sequentially, inboard first then outboard. A little more attention grabbing...
Old Jul 18, 2015 | 09:31 AM
RJ1's Avatar
RJ1
Frankie do they do a continual sequential when the turn signal is on like the T Bird did??
Old Jul 18, 2015 | 09:52 AM
Frankie the Fink
Army
Yes - they are setup for 2 or 3 tail light sequential turn signals....as the instructions state you choose which wire you want to use for the 2 tail light option (our Corvettes).....one wire has a quick delay between the sequencing and the other a longer delay...you choose what you like...
Old Jul 18, 2015 | 10:17 AM
dcaggiani's Avatar
dcaggiani
I went this route
It is a direct replacement bulb in LED form. Works great in my 64 RestoMod. They are $19 per bulb times 4 lights at Superbrightleds
Regardless of your choice - it is a great improvement!!!!
Dan
Old Jul 18, 2015 | 03:18 PM
ohiovet's Avatar
ohiovet
2016 C1 of Year Finalist
Glenn,
I have had a few people return the LED tail lights because I didn't send them the chrome housings. That's why I include the disclaimer.
What the hell do they expect for $ 50 or so???
Bruce B
To LED Tailights
Old Jul 18, 2015 | 04:19 PM
kingwoodvette's Avatar
kingwoodvette
Originally Posted by dcaggiani
I went this route
Dan
If you go this route be sure and follow their instructions about which color of bulb to use. As I remember you use the red bulb even though you have the red lense.
Old Jul 18, 2015 | 04:36 PM
TJefferson2020's Avatar
TJefferson2020
Originally Posted by ohiovet
Glenn,
Bruce B
One thing that's not clear on your ebay ad is the number of lighs - is the price for a set of two or four?
Old Jul 18, 2015 | 07:08 PM
ohiovet's Avatar
ohiovet
Check your private messages on this Forum.
Bruce B
