wiring question
Old Jul 17, 2015 | 09:48 AM
Peter A.'s Avatar
Peter A.
Default wiring question
Hello everyone. I'm trying to get the dome lights and interior lights to work on my 65 coupe. I checked all the fuses,and they are fine. Does this vehicle have a secondary fuse panel somewhere ? If not I'm guessing a new headlight switch. Any thoughts ?
Old Jul 17, 2015 | 09:53 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
No secondary fuses....if the dome lights don't work via the headlight switch its usually a problem with a contact at the face of the switch....an easy fix if that's the case but the switch will have to come out. There is a cheesy arrangement where, when the switch is turned fully counterclockwise to activate dome/interior lights, a little tab must make contact with the switch housing. This connection can become corroded a bit and that's all it takes. A few swipes with some emery cloth and maybe a little judicious bending of that tab usually clears things up.
The connection is bottom center in this pic; rotating the **** will show you how it works.
To remove the switch you press a silver button on the bottom of the housing to release the **** (pull the ****/shaft out)...then unscrew the bezel with needle nose pliers (CAREFULLY). Detach the electrical connector and remove the switch to examine/fix it.
Old Jul 17, 2015 | 10:44 AM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
I'm cautious, I would disconnect the battery while investigating. Dennis
Old Jul 17, 2015 | 10:47 AM
Frankie the Fink
Army
Of course...
Old Jul 17, 2015 | 11:11 AM
Peter A.'s Avatar
Peter A.
Default still no go !
Originally Posted by Frankie the Fink
Of course...
I did exactly that just now. Disconnected battery,removed shaft and switch,blew out with slight air pressure, cleaned contact with CRC, re-connected, no go ! Checked switch with multi meter. Power in but not out. I will have to get a new switch from my local NAPA. Thanks for all the help.
Peter A.
Old Jul 17, 2015 | 11:14 AM
Frankie the Fink
Army
Too bad - always good if you can keep an original switch.
A word of caution on repro switches....a whole bunch of them don't like the headlight load our cars carry and start 'strobing' when the headlights are used due to a weak internal thermal circuit breaker. I put headlight relays in one of my cars after dealing with the issue.
Install the new switch and run the car on high beams for a while before you do the 'happy dance'...
Old Jul 17, 2015 | 12:22 PM
tuxnharley's Avatar
tuxnharley
Do the lights come on when you open the doors, but not when you use the headlight switch? If so, then the advice in this thread is spot on.
If they don't come on when the doors are opened you have a different problem. My first guess in that case would have been the fuse, but you've already checked that. Next would be door switches, then trace the wiring for an open.
Good luck!
Old Jul 17, 2015 | 12:41 PM
Peter A.'s Avatar
Peter A.
Default Done
Good luck!
Just finished installing new switch, problem solved ! thanks again for all the advise.
Old Jul 17, 2015 | 12:54 PM
Frankie the Fink
Army
One thing is for sure -- you're quick !
Old Jul 17, 2015 | 01:17 PM
Peter A.'s Avatar
Peter A.
I had a 64 back in the day, so once I read your responses, it all came back really quickly. Having been in the automotive field for 40+ years also does not hurt. I can't stand things that don't work.So when I called NAPA and was told that they had an Eichlin switch, it was a no brainer.Why re-install the hanging bad switch when new is available ?
thanks again
Peter
To wiring question
