L-76 rebuild. 1964 327/365hp
Old 07-29-2015, 10:29 PM
Charlemagne65
Charlemagne65's Avatar
Default L-76 rebuild. 1964 327/365hp
I just purchased a new air cleaner base for my 327/365 engine. I have rebuilt the engine to the original specs including the Holly 2818,carb. The problem is the float adjustment screws (on the bowls) hit the underside of the air cleaner base keeping it from seating properly on the Holly carb. Anyone know what I've done wrong?
Old 07-29-2015, 10:38 PM
Mike Geary
Mike Geary's Avatar
I seem to recall seeing float adjustment nuts that were extra tall.
Maybe later Holley style, or aftermarket stuff.
Have you tried using 2 gaskets on the air horn?
Got a photo?
Old 07-30-2015, 12:49 AM
ghostrider20
ghostrider20's Avatar
The original air cleaner base has recesses to clear the bowl hardware. Are you sure you have the right base?
Old 07-30-2015, 07:00 AM
Charlemagne65
I called Long Island. They said that is the correct base for that Holley 2818 carb. I don't really want to manipulate the new base.
Old 07-30-2015, 07:05 AM
ifitgoesfast
ifitgoesfast's Avatar
Default pic
I have the same engine. Can you post a pic of base underside and carb top?
Old 07-30-2015, 08:59 AM
Charlemagne65
Default Picture with carb
Old 07-30-2015, 09:06 AM
ifitgoesfast
Have you tried to lift (to avoid scratching the underside) and then rotate the air cleaner base about 3º clockwise (if you're standing on driver's side)? The raised bump is supposed to be directly over the bowl screw. While yours is in the vicinity, it doesn't look like it's directly over it. Put your finger under the base and feel for the screw, but try not to scratch it. The incorrect position might be caused by how much you've inserted the rubber hose into the crankcase tube. If so, try backing off a bit.
EDIT: How about a pic of the carb only? Let's see what that screw looks like.
BTW, you're missing the flame arrestor metal screen that goes over that larger tube on the right for the air cleaner base.
Old 07-30-2015, 10:40 AM
MikeM
MikeM's Avatar
Received 1,843 Likes on 1,398 Posts
Most air cleaner bases have tangs that lock into a notch in the carb air horn. I don't see that happening here. Looks like the bumps for the float screws are way out of alignment.
Old 07-30-2015, 11:51 AM
Charlemagne65
Here is the 2818 Holly carb
Old 07-30-2015, 11:54 AM
Charlemagne65
What is the other (tiny) fitting on the bottom air cleaner and where does it go? Looks like a small vacuum line to somewhere?
Old 07-30-2015, 12:20 PM
MikeM
MikeM's Avatar
My mistake. I forgot that carb has side hung floats.
Maybe that hose nipple is for the hot air choke tube?
Old 07-30-2015, 12:44 PM
ifitgoesfast
The L76 air cleaner base only has the one bump for the screw on the forward bowl. Not sure how the rear clears, but it does on mine. The OP's base isn't way out of alignment, just a little. I was guessing about 3º because I know where the bowl screw is, which is driver's side just in front of the air horn.
Old 07-30-2015, 12:55 PM
ifitgoesfast
clean air tube
It connects to a skinny rubber hose which goes over the passenger side valve cover, behind the passenger side exhaust manifold and to a metal tube, then connects to it near where the spark plugs are and bottom of exhaust manifold. I don't have an AIM at work, but you can find the details there.
http://www.parts123.com/corvettecent...0050b&ukey=751
Steel tube from beneath exhaust manifold to top of engine near valve cover, with rubber hose to top of carburetor air horn or air cleaner. This tube provides warm clean air for the choke.
BTW, looking at your carb, it's hard to tell how thick that bowl screw he'd is. But it should clear once you rotate so that the bump is directly over it.
Old 07-30-2015, 01:00 PM
Mike Geary
Mike Geary's Avatar
OK this problem intrigued me to the point of getting off my butt and popping the hood on the 365.
In the photo, you have the base rotated too far clockwise (from a front of the car view).
This is causing interference with not the float screws, but the fuel inlet banjo fitting. That's what the relief bump is for.
The small nipple, which is indeed for the hot air choke inlet tube, should be at 10 o'clock.
The base has 7 cutout windows -- the middle cutout should be close to centered with the distributor. You can see how far yours is rotated CW.
Try that and see if it helps.
BTW: put on the correct bracket for the throttle return spring and it won't be over-stretched. Also, can't tell if you have the metered orifice fitting on the driver's side of that gorgeous 2818. Eric Jackson's work??
Old 07-30-2015, 01:11 PM
ifitgoesfast
Sorry for the confusion. I'm at work and assumed it was for the screw, and was guessing it had to rotate the other way. What Mike posted makes sense, and would answer why the rear screw clears, which puzzled me, because both clear.
If you look at how your base is angled, it indeed looks like it's coming from the fuel connection.
Old 07-30-2015, 05:34 PM
0Corvettes by George
Former Vendor
Corvettes by George's Avatar
You are correct about the "clocking" of the air cleaner base in photo provided---but--- the photo was used to show the attitude of the base to carb not seating----trust me, I rotated the base in all directions to attain seating--- but to no avail. Big but; if the base is rotated 180 degrees, it flops right down.
I see that the inner portion of the base is spot welded at an angle, could this particular piece have been welded in the opposite angle?
Old 07-31-2015, 03:24 PM
Mike Geary
Mike Geary's Avatar
The inner portion is probably welded on correctly since the 2 hose nipples are correctly oriented. The inner section actually gives you more clearance in the front, since it's slanted up going forward.
This is quite the mystery. My next step would be to shoot the underside of the base with some quick-dry paint and then try to seat it.
The exact area of interference will be clear from the witness marks.
If it is ONLY the forward float adj. screw head, that suggests to me that the air cleaner housing has a problem. Maybe a new vendor with new tooling.
Here's a reference photo to compare your side view against:
Is your fuel inlet maybe rotated too far up, causing interference with the hose? Seem to recall that happening to me once.
Note the spring and bracket.
To L-76 rebuild. 1964 327/365hp
Old 09-21-2015, 01:41 PM
Charlemagne65
Sorry I forgot to respond to this some time back..... It actually turns out that Mike Geary was right. The fuel inlet was rotated to far up! A quick adjustment turning the fuel inlet down fixed the problem. Thank you all for the help. I just need to get a few of the engine pieces that will finish my 327/365.
Old 09-21-2015, 01:50 PM
ifitgoesfast
vacuum advance (236)???
Old 09-21-2015, 06:12 PM
Charlemagne65
I think I need to find the correct distributor with the proper vaccum advance? Any ideas?
Quick Reply: L-76 rebuild. 1964 327/365hp
