64 Headlight problem
Old Aug 2, 2015 | 09:15 PM
Oaker57's Avatar
Oaker57
Default 64 Headlight problem
Searched the Archives, and couldn't really find an answer to this problem.
Short of the long is, it's a 64 that had the buckets and motors completely rebuilt from scratch, as the whole nose was glassed in when I got it. It's now restored to factory spec's. as all new repro parts were needed. That was two years ago and the buckets have been working great, until about 2 weeks ago when the drivers side stopped opening, (passenger side opens and closes fine) the motor is working, I can hear it running, but the bucket doesn't engage, also won't move with the hand wheel either. It will however work if someone lightly pulls up on it when I pull on the switch, it then goes all the way up and back down with no problems. And as long as I don't park it all the way down, I can keep going up and down all day, but as soon as it's closed all the way, it needs to be boosted open again.
Can anyone tell me where I need to look first, I have no idea where to start??? I know one of you guy's must have run into this....
Thanks in advance....
Old Aug 2, 2015 | 09:17 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Pull the headlight motor and open it up. I'm no expert but either the gear is junk or the grease is jelled up
Old Aug 2, 2015 | 09:24 PM
Oaker57's Avatar
Oaker57
I can see the gear "maybe" being a problem, but do you really think the grease could be jelled up in only 2 yrs' time....these were brand new motors, and the gear seems to be fine all the way up and down once it gets an initial boost???
Old Aug 2, 2015 | 09:34 PM
Nowhere Man
Don't know I can't see though anything yet.
Old Aug 3, 2015 | 06:05 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
Removing the motor is an electrical connector, a hairpin clip and a bolt - you don't have to remove the hood if you're careful. A 10 minute job. Then you can test the headlight bucket. It should roll up and down with the flick of two fingers; if not that's your trouble. If it works your main gear in the motor is most likely galled. Secondarily, you may have corrosion in the harness/connector not allowing full current to the motor (since you say you hear it running). I doubt the last part though if even the thumbwheel doesn't work.
My money is on the main motor drive gear being shot...if somebody 'gooses' the bucket a bit and that makes the headlight work its prob because the motor is getting some 'bite' on a remaining good tooth on the drive gear. When the bucket is allowed to fully close you're in the galled tooth area again.
Old Aug 3, 2015 | 10:03 AM
MasterDave's Avatar
MasterDave
Moderator
The gears only turn 1/2 of their circumference for their whole life. If the gear is indeed galled/bent some, just turn it over and you will have a brandy new gear.
Old Aug 3, 2015 | 01:09 PM
Oaker57's Avatar
Oaker57
Thanks Frankie, thats where I'll start...
Old Aug 3, 2015 | 10:31 PM
Oaker57's Avatar
Oaker57
Ok guy's. got home from work and went right out to the garage, and with Frankie and Dave's advice in mind I had the motor out in 10 min. After determining that the bucket moved freely by hand, I proceeded to take the gear cover off the motor. And just as you guy's, along with "Nowhere Man" all predicted, sure enough the gear was all worn down on one side. Per your instructions, a simple 180* rotation of the gear and some re-greasing fixed it right up. Threw it all back together and the buckets work like new again. And the whole process took me all of a half hour. Thanks for all the help, you guy's make these jobs a lot easier to deal with. I just can't believe that the darn thing wore out in under 2 years, although I did run em' up and down a lot when I first had them repaired as I was so happy to see them working...
I took a couple of pic's, but I didn't think to take them until after I greased it up. but if you zoom in closely you can see how the teeth were inversely concaved on the right side...(after the flip)
Old Aug 4, 2015 | 07:58 AM
Frankie the Fink
Army
You were lucky with the 180* gear flip - it doesn't always work depending on how bad the gear is galled. I don't recommend it anymore since correct repro gears are now available so cheaply - glad it worked for you.
My theory is that after one of the lights gets slow the driver has to hang on that dash switch to get that one upright or completely closed; all the while the motor on the 'quick' side is grinding away and eventually the gears pay the price.
Unfortunately the 'limit switches' in our C2s limit nothing. However there is a YouTube video on how to convert them to real limit switches which cut power when the buckets come to rest or fully open. Lots of trouble though for something that's not that hard to fix..
Old Aug 4, 2015 | 08:40 AM
Nowhere Man
They are not limit switchs. They are for your tel tel light in the dash. That's it
Old Aug 4, 2015 | 06:18 PM
Frankie the Fink
Army
Errr. That is what I said.
Old Aug 4, 2015 | 06:37 PM
MOXIE62's Avatar
MOXIE62
Same thing happen to me. The reproduction gear is junk. Compare it to an original and you will see how much thinner the teeth are then the real deal. Another situation where they spend the money on tooling only to make a weak gear.
Old Aug 4, 2015 | 10:57 PM
Oaker57's Avatar
Oaker57
I totally agree with your theory, as that's exactly the scenario I often have to go through to get them lined up properly.
I didn't know you could buy new gears, I haven't noticed them in any catalogs. I will have to get a pair to keep just in case.
Although, if this happens again I might have to consider the new Detroit Motor system, they look like a pretty sweet system.
Thanks again for the help and advice, it's nice to have it working again.
Old Aug 5, 2015 | 07:33 AM
Frankie the Fink
Army
The later repro gears work fine; I understand the older ones had issues.
They are what they are.
Anyway, what's your alternative if you have a worn out original ? NOS - not likely ? Original - worn out as well ? Rebuilt motor - guarantee it has a repro gear ?
The later repro gears will prob outlast the car's owner for the few times the headlights come up/go down on classic cars.
Old Aug 5, 2015 | 09:31 PM
Oaker57's Avatar
Oaker57
The later repro gears will prob outlast the car's owner for the few times the headlights come up/go down on classic cars.[/QUOTE]
Yep....probably will. Looks like Paragon has them for about 26 bucks,
I think I'll order one to keep on hand, since this one went so fast.
Thanks again for the help........much appreciated.
Old Aug 5, 2015 | 09:56 PM
MOXIE62's Avatar
MOXIE62
Thanks again for the help........much appreciated. [/QUOTE]
I was told you need to operate at least once/month to keep motors from freezing up.
To 64 Headlight problem
