The battery gauge on this 66 looks unresponsive. It always stays just a tick to the right of center. What is the test for determining functionality? I've got a meter but not sure of settings. Thanks in advance.
Turn the high beams on, play radio at high volume, step on the brakes and honk the horn simultaneously with the key ON but engine OFF and you should see some major deflection to the left side.
You may just have a healthy, perfectly functioning charging system....
With a good battery charge, that's what you should see with the engine running. Close to zero with everything off, deflection to the left if you turn on headlights. With the battery low on charge, the needle should deflect right to show charging. Sounds like yours is in good shape.
I just went through this last weekend on my 60. Just to the right is correct. With engine off mine goes to about -13, about +7 when I first start it and within 30 sec. it goes to just the right of 0.
If I turn the headlamps on, rotate the buckets, turn the radio on and step on the brake pedal- all at the same time, the needle moves ever so slightly to the left. I mean ever so slightly. I don't ever see a discharge reading under normal operation. I guess that's a good sign but I would expect more deviation in such a gauge under discharge.
It's not an amp gauge, it's a voltage gauge. The voltage drop across a piece of wire run from the starter to the horn relay is used to deflect the needle. So if it doesn't deflect left momentarily when you turn on the lights, either there is a very strong battery source, or the resistance of the wire is very low. Both those are good things. The only other possibility is that the gauge isn't deflecting properly. I think you can take a 1.5 volt battery and momentarily connect it across the gauge to check deflection, but it's been a long time since I tried anything like this and don't remember the details. If it were me, I wouldn't worry about it. If it deflects left and right slightly with changes, just be aware of the movement so you'll know if it's charging when it should. Unless I had to have the gauge out for something, I would just note the operation and use it as is.
Just for grins, turn on the headlights and have someone watch the gauge while you wiggle the bulkhead connector just below the master cylinder. If you see changes as you wiggle, I'd pull the connector off and clean the pins on both sides of the plug. Post back what you find if you do that. (Engine OFF)
With the engine running and using a meter what is the alt putting out? If it's 14.1 or around every thing is normal and don't mess with anything. If not you have a problem. If you under stand how the gauge works your understand.
Sorry, I don't understand that sentence.
It's been like this seems forever. I've never had charging issues or a gauge that moved erratically. I always do repeated gauge checks while driving this car. I feel like a pilot running thru his instrument checklist. It never deviated enough to catch my eye which is why I wondered if it worked at all. I did the fuse block connectors and there is no change.
That the gauge is not reading volts. But the diffreance between the horn really and voltage regulator
It is indeed reading volts. It is reading the voltage drop on a wire connected between the starter and the horn relay. That wire is in parallel with the gauge connections and reads the positive or negative based on the current flowing through the resistance of that wire. Since it is connected in parallel (a shunt) it reads the difference in the voltage between those two points that is dropped on that shunt wire. It is a voltage meter.
Mine has been that way for 13 years
If you want to be sure the gauge moves take a AA battery and MOMENTARILY touch the terminals across the back of the battery gauge. Battery Connector off. 1.5 volts will cause a full scale deflection of the gauge . just momentarily flash the terminals don't hold it there
Also you should have 12 v to ground on both the black wire and the black wire with white tracer at the battery gauge connector
I have never been able to get a major deflection on my gauge and assume I have a high resistance connection somewhere although I have cleaned the firewall connector and all other terminations
Anybody that drives these old cars and is smart has a gauge scan timer in his forebrain. I go through mine at least every couple of minutes when underway. The practice saved my original '61 engine once.
The gauge shouldn't be erratic; hence the 'regulator' part of "Voltage Regulator". Personally, I would live with what you have...you could spend money, time and get frustrated and perhaps not make it any better...
Easiest and cheapest solution is to buy one of these digital volt meters and stick it in the cigarette lighter plug. I got this one for $1.90. That included shipping from China.
