Battery cable size
Old Aug 10, 2015 | 01:00 PM
GEM '62's Avatar
GEM '62
Default Battery cable size
I am running a 12' ground cable on my 62, can I use 4 gauge cable or do I need to step up to 2 gauge?
Old Aug 10, 2015 | 01:04 PM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
12 ft ! use no 2. Why not use the frame for ground like GM did on C-3's ?
Old Aug 10, 2015 | 01:08 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
Larger is always better when considering high current wiring, like battery (+) and (-) cables. If that run is really 12 feet, I'd suggest 0 gauge cable, maybe even 00 cable.
Jim
Old Aug 10, 2015 | 01:18 PM
GEM '62's Avatar
GEM '62
I am installing a keyed cutoff switch inside the car. The switch is 6' from the battery and also 6' from the ground connection on the engine so a total of 12'. I guess I could run from the battery to the switch and then to the frame which would cut the total to around 7'. I could then run another short cable from the engine to the frame to insure a good engine ground.
Old Aug 10, 2015 | 01:58 PM
Powershift's Avatar
Powershift
This is definitely needed if you use the frame in the ground circuit.
Years ago when I put the battery in the trunk (over RR wheel) of my 390 AMX I used #00 welding cable for all my connections. I also used soldered end connections.....which tended to make this cable less flexible and more solid at the ends. The "short piece" from frame to engine acted like a solid motor mount(s) and rattled your teeth when driving the car. So just be careful how you design and install this piece on the car.
Consider a bit smaller cable size and a little more length than I did...or get professionally crimped ends
Larry
Old Aug 10, 2015 | 03:37 PM
wib1961's Avatar
wib1961
Any good welding supply distributor that sells welding cable should be able to crimp ends on for you in a competent manner. And the welding cable makes great battery cables.
Old Aug 10, 2015 | 03:54 PM
JohnZ's Avatar
JohnZ
On the rear-mounted battery cars I've built in the past (Grand Sport replica and three Cobra replicas), I always used #00 welding cable with crimped copper terminals; the local welding supply house has every size terminal you'd ever need, and I bought my own terminal crimper (you smack the plunger with a BFH).
Old Aug 10, 2015 | 04:04 PM
MikeM's Avatar
MikeM
I need one of them. Thanks for the picture. Always wondered how that was done.
http://www.ebay.com/itm/TEMCo-LUG-CR...-/400441203422
Old Aug 11, 2015 | 08:20 AM
GEM '62's Avatar
GEM '62
Thanks guys. I expected to go heavier but didn't expect to go as high as 00.
To Battery cable size
