66 SB - Where does heater fan draw it's air?
Just got my 66 sb back from the body shop where it was stripped down to the fiberglass and repainted.
First time I turned on the heater fan I got a huge cloud of body shop dust in the car. Body shop did a great job on the paint but they either forgot to block of the heater fan intake or clean it out after they were all finished.
So what can I do to prevent further dust storms in the car?
Received 2,130 Likes
2015 C2 of the Year Finalist
Dan
The OP didn't ask about the pull for air ****, he asked about the heater blower. My response was that heater air is drawn in from the cowl vent, and the body shop debris likely settled in the vent baffles and heater box.
Dan
I don't know why my post apparently irritates you. The same vents you are talking about is where the air is drawn into the heater box to blow into the cabin when the 'air-pull" **** on the fan switch is pulled out. If the cable is pushed in, the cabin air is recirculated. I'm not talking about a/c, I'm talking air vent from the outside that all c2's have. My response and yours are not in conflict, we both think the dust is being pulled from the cavity below the cowl vents.
Agreed. I often see posts here where someone seems to answer a question as though the poster above who did likewise...didn't.
No harm, no fowl, chalk it up to oversensitivity on my part.
Dan
Your original post wasn't there when I was typing my answer, if you look at the times, they are within a minute. I didn't intend to step on any toes.
Guys lets not be over sensitive. I just ask where the dust comes from. Multiple answers were the cowls underneath the windshield wipers. That's what I needed to know and that is what I will clean out. Thanks.
The dust that's already been pulled into the heater box will have to gradually clear itself into your cabin.
Received 1,857 Likes
To clarify, the heater and A/C system airflow patterns are different. The heater system operates only on outside air, which enters the blower from the plenum below the wiper grille; if the heater system has the "air" door closed (Air-Def **** pushed all the way in), no outside air is allowed inside the car, and there is no setting that will allow use of inside air.
With factory A/C, there ARE two air entry paths - outside air is admitted through the plenum below the wiper grille, into the A/C adapter assembly which replaces the passenger side kickpad vent, into the blower. Inside air provides max cooling when the door in the adapter assembly swings the other way, admitting air from inside the car and none from the outside.
