US made sand blaster
Steve
But it was inexpensive. And boy what a mess blasting, might be good to figure a way to capture the used sand and re-use it. It is a LOT of work.
There are also companies using truck mounted blasters that come to you.
Not sure if all their equipment is made there, but it is good quality stuff. I've had one of their cabinet blasters and a portable pressure blaster for over 15 years and both have served me well.
Charles
Steve
Others are Brut and a few sold by Eastwood.
The USA made ones are $$$$ and they also require a good sized compressor (probably 5 hp or so).
Check your "yellow pages" or internet for sandblaster companies that may be in your area and consider using one of them. Here in Louisiana (near the water) we have quite a few. Then bring the frame to them and let them do the work.
Some years ago it was determined that sandblasting without breathing protection (respirator minimum, supplied breathing air preferred) will cause lung issues. That is why there are a lot fewer sandblasters for sale and a lot less sandblast facilities now compared to years ago. Too many health issues and $$$$$ lawsuits.
Blasting one time with a respirator should not hurt you, but when you factor in cost of equipment, etc I would recommend trying to farm the work out. But if you do, find a good company, and stay around to see how the job progresses. Inexperience and the wrong media or air pressure can create frame issues.
Larry
Charles
Larry
Charles
I checked their website, they do not offer portable units. Thanks.
Steve
I will probably be doing more than this frame. I have a couple of older vehicles that will need some clean-up also. So would rather purchase one to have rather than finding someone to come to me. I was thinking about using Walnut media and was going to try to capture it for re-use.
Steve
Steve
If you sandblast, find slag sand.
Steve
o
The guys that do this for a living today in a recognized/responsible company use supplied breathing air. The reason is based on (medical) experience over the years.
FWIW
Larry
Can you still buy silica sand? I haven't seen it for years.
Workers' exposure to crystalline silica must be kept as low as reasonably achievable (ALARA) below the exposure limits in Table 5-4 in the Occupational Health and Safety Regulations.
