LED Dash Lights
Old Sep 3, 2015 | 02:12 PM
Jefjak's Avatar
Jefjak
Default LED Dash Lights
My car is a '65 327/365. I am planning to replace my dash wiring harness, and while i'm in there will replace the dash lights w/ LED's. I have read the numerous posts and articles on both topics.
I have read that the 3 lamps for the high beam indicator, ignition switch, and cigarette lighter are a different type than the rest of the dash lamps, and also the 2 for the parking brake alert and headlight alert.
I don't see any mention in any of the recent articles that discuss LED replacement lamps that anyone has used anything different for these 5 lamps. Has anyone replaced these lamps w/ LED's? and if so, what have you used?
Thanks in advance for your help!
Old Sep 3, 2015 | 05:22 PM
Geralds57's Avatar
Geralds57
2024 C1 of the Year Winner - Modified
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
I just installed LED's in our '57 and boy did it make a difference. The left bulb is a factory type, the 2nd is LED was the first one I tried and it brightened them up but the 3rd one of the far right really made the difference. I left the factory bulb in my bright indicator. I used the middle LED in my turn signals and the flat LED's in the gauges. The turn signal arrow went from pale Green to Bright White. The flat one would probably work fine in the signal arrows. I can finally read my gauges clearly at night.
Old Sep 3, 2015 | 05:51 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
your problem is not the light bulbs but the light filters in your cluster and the backing paint in the cluster. they both are filthy and not letting all the light though. if you ever had a chance to look at two cars side by side one with a restored cluster and one with a original cluster you will see the difference. your fancy widget light bulbs are just a band aid
Old Sep 3, 2015 | 06:12 PM
leif.anderson93's Avatar
leif.anderson93
Damn, Keith...you can sure get nasty from time to time. Do you know the OP's car personally?? From personal experience, I restored my dash cluster, installed new wiring harness and all new OEM bulbs...at night time they are still so dim as to be virtually useless. Had I known about the LED's availability when I did mine I would certainly have installed them. May make for a nice winter project.
Old Sep 3, 2015 | 06:19 PM
Nowhere Man
I don't know how you can say what I wrote is nasty But I will stand behind my statement. I don't know how you restored your cluster but I know the two cluster my dad had sent out to be professional restored is way brighter then the cluster on dads other unrestored car In the rare times the cars sees night time driving the clusters in the two are bright as any new car. That holds true for my Chevelle.
Old Sep 3, 2015 | 06:21 PM
Jefjak's Avatar
Jefjak
Now there you go dragging me right into that project creep everyone warns about! But I'm sure you are right about the condition of things behind the scenes. I will certainly clean that up while I have things apart.
Old Sep 3, 2015 | 06:23 PM
Nowhere Man
You have to remove the cluster and take it completely apart to clean it right.
Old Sep 3, 2015 | 06:43 PM
Jefjak's Avatar
Jefjak
Understood - it's coming out
Old Sep 3, 2015 | 06:44 PM
VetteRed1965's Avatar
VetteRed1965
the dust settles and the paint gets faded...Led are the way to go
Old Sep 3, 2015 | 06:51 PM
Nowhere Man
if the car ever spent time in a body shop with the cluster in the car the dust got in there. I don't care how well you seal things up. body shop dust gets everywhere and being 50 years old is not helping matters either
Old Sep 3, 2015 | 07:30 PM
66RBS's Avatar
66RBS
Re the parking brake and headlight alert bulb I don't think you will find LED equivalents. These are a #257 bulb that has an internal blinker. Hard enough to find the incandescent versions
Randy
Old Sep 3, 2015 | 08:05 PM
Jefjak's Avatar
Jefjak
Randy
I didn't know they're supposed to blink! My current ones illuminate, but don't blink. Guess I'll see why when I get back there. I'll look for the 257's. Thanks!
Old Sep 3, 2015 | 08:07 PM
Nowhere Man
Only the parking brake light should flash. The headlight tel tel light should be soild. A 257 bulb takes a while to warm up before it flashes
Old Sep 3, 2015 | 08:48 PM
JackTripper's Avatar
JackTripper
Turn 12!
What is that fitting called? I would like to replace the interior and trunk lights with LEDs. Everything else, I would like to keep orginal since my car is numbers matching.
Old Sep 3, 2015 | 10:27 PM
Geralds57's Avatar
Geralds57
I believe they are 1815 bayonet style bulbs.
Old Sep 3, 2015 | 11:10 PM
66RBS's Avatar
66RBS
According to my 66 owners manual. "A flashing red LIGHTS indicator on the instrument panel, gives warning whenever the the headlights are turned on but not fully opened.
Also owners manual lamp data says #257 for both parking brake and headlight warning
Randy
Old Sep 3, 2015 | 11:17 PM
66RBS's Avatar
66RBS
From my 66 owners manual. Should be same as 65
1445 is bulb for high beam,ign switch, and cigarette lighter
1816 is for instrument panel
257 is for parking brake and headlamp warning
Randy
To LED Dash Lights
Old Sep 4, 2015 | 07:57 AM
Jefjak's Avatar
Jefjak
Randy
It is same for my car. I know what the incandescent versions are. I'm going to use the warm white LED's from superbright led's to replace the 1816's, and was wondering if there is an LED equivalent for the 1445 and 257. Didn't realize 257 flashes. Superbright website says same lamp for 1816 and 1445. I'll stick w/ 257 for parking brake/ headlight warning. Thanks
Old Sep 4, 2015 | 08:06 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
I've had my '63 cluster apart twice and cleaned everything thoroughly; even so I would describe the dash lights, even at full brightness, as a dull glow....very marginal.
I would consider those flat LEDs for at least the gauge lights....
Old Sep 4, 2015 | 08:33 AM
Geralds57's Avatar
Geralds57
You won't be disappointed with the flat LED's. I'm very pleased with them.
