There is no equivalent in price, ease of installation, or, quality to Vintage Air Gen IV.
None - don't exist.
Here is my '63 last Saturday after an hour on the highway in 93* with Vintage Air A/C with just a heavy duty fan clutch and over-sized radiator fan (no electric fan and stock radiator). Note the temp gauge and note the thermometer in the vent (excuse my gnarly feet)
And yes that's 175* coolant temp and 41* coming out of the vent
Frankie,
Would you mind putting up some pictures of the vents ?
I want ac in my 64 vert (with a big block) and am hemming and hawing on what to do with the vents.
FYI - the vents on each side of the center console are pretty much stock and non-directional but they blow hard. The outboard A/C nozzles for the mid-years are in plastic housing that span a short distance under the dash (as shown)...you can see them on the floor and then installed in the attached photos. On a '63 the LH nozzle doesn't go completely to the left unless you shuffle some things around so my positioning is a compromise that I'm fine with.
I toyed with some other nozzles that just hang down with hoses directly attached and no plastic housing but they looked no better and routing the hoses was problematic (I should have known Vintage Air had already figured it out)
I guess I 'm in the minority on the clock hole vent....it really looks outa place to me. Ruins the asthetics of the whole clock console imho...(bugeyed sorta?...no offense meant to anyone, just my preference) So much so that I spent a bunch on having my original gauges restored and/or updated to preserve the original appearance...including the clock and tach.
The dash and stock old school look on the C1's instruments is one of the most pleasing parts of the C1's to me...just beautiful.
However those center side console vents look like they wouldn't detract much from the instruments or dash vintage look ...if they could be made to fit.
The Old Air System was in my car when I bought it 4 years ago. I replaced the rebuilt GM compressor this year for the new version. The system works very well and I run it all summer with the top down. The front seal on the compressor started leaking. When temps get in the high 90's I put my top up enjoy the cool air. I have had no over heating issues with a factory cooling system.
You basically have a choice between the VA and Old Air. They both use the same compressors. Forum members favor the VA system for some reason. It would be interesting to get an opinion from someone who has both.
Well - if Old Air had their installation manual available on-line a cursory comparison could be made.
I know a bunch of top restorers and none of them use anything but the V/A system - so not sure who has experience with both systems.
I did have Nostalgic A/C in my '67 Chevelle and it was ridiculously lame....air flow weak, temps not optimal, controls half-assed.
Sooo - I'm a little leery of anything but what the majority of users have had good luck with.
If O/A had performance equivalent to V/A and still preserved the glove box entirely that would be an advantage.
Maybe you can post a pic as I did to see how the system performs in the real world...
Reading through AC posts over time when they came up and user experience threads convinced me to go with Vintage Air.
The later VA kit with electronic controls and stepper motors is a nice touch. No mechanical push-pull cables with the Gen IV system.
Installation can be a bit of a bear, especially the under dash work. VA also provides customer support. Inquiries and/or questions are promptly replied to. One part in the system I received had a defect (buggered up threads). VA promptly sent out a replacement.
Complete and ready to go, system up and running, having AC in these old cars makes the driving experience all that much better. Actually, a bunch better.
Spoiled? . umm........could be!
John
