A Mechanic friend who does not work on a lot of C2's has a customer's 66 390 HP coupe in for strut rods, U joints, shock mounts and shocks. Put the car back together with new parts and the rear is bouncing as if the shocks are shot. Is there anything in the alignment possibly so far out the car won't stay on the road?
He's asking me, thinks because I have one I know everything.
Also the new strut rods may not be the correct ones for his car either. The bushings in the strut rods of later 70's vettes were of a slightly different size than the C2's and they could have been replaced easy enough with out the mechanic knowing.
Just my guess.
Just my guess.
Did it have a wheel alignment?
65-StingRay
Thanks, I told him I wouldn't try diagnosing this without first aligning it but he's a stubborn straight axle guy (restores GTO's for a living). I'll report back. Glad he's not working on my Corvette.
The default answer is the rear spring. Is the stock 9 leaf spring being used or is it the 340 lb fiberglass unit?
If the production steel rear spring has been replaced with an aftermarket composite spring, they don't have any interleaf friction, and the rear suspension will have the "bouncy-bouncy" syndrome until the rear shocks are replaced with a pair specifically valved for tight rebound behavior. There is no other solution, short of putting a steel spring back on.
Thanks John and everyone, I'll inform him & let you know the resolution.
John is correct as always but I have found that even a stock spring has more bounce than modern suspensions and was quite bothersome for me. I used Koni adjustable to control rebound but the QA-1's will do the job with much simpler adjustment.
