1967 convertible
Old Sep 19, 2015 | 06:10 PM
67ermineconvert's Avatar
67ermineconvert
Default 1967 convertible
hi guys i have a basically stock non matching # smallblock powerglide car
i am interested in keeping and or adding to the suspension performance with an eye on cost and comfort i know its a lot to ask for but right now it has stock front springs that need replacing and a newer multi leaf rear the car is almost unmanageable on rough new england roads it washboards like crazy. Q. is the non metal transverse spring more forgiving? should i try to at least put front coil overs and control arms on this winter with a plan to do rear coil over kit in another yr or two? will i gain anything other than tunability? should i be looking hard at some rear suspension components for my current issues ? i did a eurathane bushing kit and all front end parts last winter with a 3/4 sway bar kit. but have no loyalty to any of it i just want to enjoy the drive without losing fillings
Old Sep 19, 2015 | 06:15 PM
KC John's Avatar
KC John
C2 of Year Finalist (appearance mods) 2019
I can't help with your problem, but you are going to catch a bunch of crap for not using punctuation or capital letters. It does make it much harder to read.
Old Sep 19, 2015 | 07:02 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Go back to completely stock OEM with all new rubber bushings everywhere that includes body mounts. New stock style shocks and a good radial tire. Your car will ride and handle great.
Old Sep 19, 2015 | 07:34 PM
67ermineconvert
Thanks its pretty stock it seems to ride the same with new bushings or the old. it has new radials. the only thing i havee not replaced is anything in the rear end all shocks and body mounts
Old Sep 19, 2015 | 07:38 PM
67vetteal's Avatar
67vetteal
I agree! Al W.
Old Sep 19, 2015 | 07:40 PM
67ermineconvert
Originally Posted by 67vetteal
I agree! Al W.
so the washboarding and rattles you would attribute to hard suspension and body mounts? is the stock spring a multi steel?
Old Sep 19, 2015 | 07:45 PM
tbarb's Avatar
tbarb
If you have not already done so look at the steering box for slop. Keep the stock suspension parts and save your money.
To 1967 convertible
