M&H list 1 piece harness $339.00. Lectric Limited list 1 piece $339.00 and an additional piece $43.00.? What is correct and why two different types?
Mine was one piece, and I ordered it from Corvette America. Basic application...327, NO A/C.
Go directly to CA web site and look for #29287...'66 engine harness. Dennis
Here are the two harnesses you're asking about. From Lectric Limited...one is the engine and forward lamp harness the other is headlight bucket extension harness.
VIG6700 ENGINE AND FORWARD LAMP HARNESS, all Note: Requires use of VHX6367 to complete wiring to headlights $339.00
VHX6367 HEADLIGHT BUCKET EXTENSION HARNESS SET, all (includes pair of pre-assembled harnesses) $43.00
Same pricing for same components from M&H.
I guess I'm still confused a little. I thought once you unplug the bulkhead connectors all the firewall forward wiring was one continuous piece (except maybe for some ground wires). Right now my car is 80 miles away so I can't confirm this.
It is one Piece all the way to the headlight buckets and is plugged into each headlight most times there is no need to replace them unless the plugs are bad or they have been cut.
66 and 67 used what we always called a Siamese harness where the headlamp and engine were tied together right at the two bulk head connector plugs. 63-65 had two separate harness's (headlamp and engine).
Not to hijack an old thread, but I am planning on ordering an engine harness for my '66. This discount code doesn't seem to work anymore. Do you have an updated code?
Thank you.
Reason: update verbiage
