Pertronix help please
Old Oct 6, 2015 | 02:40 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
Originally Posted by Rob Magnano
New alternator. We keep blowing the Pertronix. My builder replaced it again and disconnected the alternator. It seems to be starting fine over the last week.
There's your first clue about where to look for a problem. With the alternator disconnected, the Pertonix gadget lives. That tells me there is something wrong with your charging system..... probably putting out more Voltage than the Pertronix can survive. I'd look there first.
Jim
Old Oct 6, 2015 | 02:47 PM
hedgehead's Avatar
hedgehead
From: I'm not doing as well as I expected, but I never expected I would
Get an MSD blaster and be done with it.
Old Oct 6, 2015 | 02:56 PM
MikeM's Avatar
MikeM
Threads like this one which are all too common are the real reason I wouldn't fool with one of these gadgets. I have no problem with a REAL, OEM manufactured electronic ignition.
That said. Here is a link that may just help you out.
http://www.vintageperformance.com/re...ow_voltage.htm
Old Oct 6, 2015 | 04:09 PM
tbarb's Avatar
tbarb
Rob,
Have you checked the charging voltage when the engine is running. If it's charging more than 14.5 volts the alternator and regulator should be checked together.
Old Oct 6, 2015 | 04:11 PM
tuxnharley's Avatar
tuxnharley
Originally Posted by Frankie the Fink
Frankie no longer posts opinions or solutions here or accepts PMs.
If anybody has questions about my prior posts I can be contacted at 'fdreano@earthlink.net' or through the NCRS tech forum.
Wow.
Old Oct 6, 2015 | 04:17 PM
tuxnharley's Avatar
tuxnharley
I don't understand why some folks are so negative about Pertronix units. I've never had a problem with them in my '67 Corvette, or my '67 Mustang, or my '73 Jag/sbc.
Guess I must just be lucky........
Old Oct 6, 2015 | 04:23 PM
Don Birmingham's Avatar
Don Birmingham
6th Gear
Default pertronix
Took me two times for this to happen when I installed the Pertronix 2 in the 65, I hope your mechanic has removed or bypassed the ballast resistor on the firewall...
Old Oct 6, 2015 | 04:49 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Originally Posted by tuxnharley
I don't understand why some folks are so negative about Pertronix units. I've never has a problem with them in my '67 Corvette, or my '67 Mustang, or my '73 Jag/sbc.
I'm not negative about them. It's just my points have yet to fail. And I don't like to fix what's not broken just to tinker with my car. Points have been working for 50 odd years that's good enough for me to believe they work just fine for a STREET driven car.
Old Oct 6, 2015 | 05:12 PM
vettepoor's Avatar
vettepoor
Active Streak: 90 Days
I ran Pertronix for several years before getting stranded when the device failed. I considered replacing it with another unit, but I wanted to know why it failed first. All the Pertronix folks wanted to do was replace it (at my expense, of course) instead of determining cause of failure. I went back to points, zero issues since.
Old Oct 6, 2015 | 06:19 PM
MikeM's Avatar
MikeM
See post #23. Do a google search on "problems with Pertronix". Problems with this device is not limited to Corvettes. Whatever the reason is.
Old Oct 6, 2015 | 06:32 PM
tuxnharley's Avatar
tuxnharley
What's the old saying - "I'd rather be lucky than good....."
Old Oct 6, 2015 | 06:33 PM
Rob Magnano's Avatar
Rob Magnano
Thank you to all that replied. I think I am on the right path now that all the kind forum members took their personal time to help us.
Thank you it's truly appreciated and I hope we soon get another mid year back on the road after 20 years.
Rob.
Old Oct 6, 2015 | 09:01 PM
  #33
MasterDave's Avatar
MasterDave
Moderator
Do not bypass the ballast resistor, it will screw up the Pertronix unit. I know this to be true.
Old Oct 6, 2015 | 09:17 PM
  #34
redstar's Avatar
redstar
From: Kingston, TN, Denham Springs, LA & Agoura Hills CA
Well, I have had the III unit installed bypassing the resistor for at least 2 years here in So CA with no problems. Maybe the first two models had problems, never used those. And I do not use the ultra low resistance coil
Old Oct 6, 2015 | 09:53 PM
  #35
FasterIsBetter's Avatar
FasterIsBetter
Are you using a Pertronix coil? I have run Pertronix in my '70 Jaguar XKE for over 10 years. Early on, I blew two Pertronix units. I was using the "stock" Lucas coil. I spoke to a couple of other Jag owners who ran Pertronix as well, and they were all using Pertronix coils. None of them had a problem. I installed a new Pertronix unit, and switched to a Pertronix coil, and no more problems. Over 10 years, no failures to the unit or the coil. YMMV, but that's my experience. If I were doing a Pertronix, I'd definitely use a coil that Pertronix says is matched to your Ignitor II unit.
Old Oct 6, 2015 | 09:54 PM
  #36
63split63's Avatar
63split63
Default Years or Miles
Claiming you have used a product in your car for 1 year or 2 or 10 years means very little . 1000 miles or 2000 miles or 10,000 is more relevant .
Most of these cars wouldn't run 1000 miles in 5 years .
Bill
Old Oct 6, 2015 | 10:13 PM
  #37
Sam Kalmuk's Avatar
Sam Kalmuk
2022 C2 of the Year Finalist - Modified
2017 C2 of Year Finalist
To Pertronix help please
Old Oct 7, 2015 | 08:26 AM
  #38
Steve59's Avatar
Steve59
Sorry to hear that Frank. You have helped me A LOT over the years.
Steve
Old Oct 7, 2015 | 09:01 AM
  #39
61 Roadster's Avatar
61 Roadster
2020 C1 of the Year Finalist - Unmodified
Corvette of the Year Finalist 2018
2017 C1 of Year Finalist
2015 C1 of Year Finalist
Steve
Likewise here, Frank. Your wit and wisdom have aided my efforts to get the 61 where it is today.
Old Oct 7, 2015 | 02:39 PM
  #40
Rob Magnano
My builder said my alternator is putting out 14.9 to 15.1 volts and has blown 2 resistors. What can I do to solve this?
Thanks.
