lights in dash
Old Oct 22, 2015 | 08:15 PM
7-11vette's Avatar
7-11vette
2025 C2 of the Year ('63 and '67) Finalist - Unmodified
2016 C2 of Year Finalist
Default lights in dash
Is there a brighter light to use in the dash other then the 1816 for the instrument panel light ?? Before I put it back together.. Have a 67 coupe since 1972, Don't fill like doing this again..
Gregg
Old Oct 22, 2015 | 08:24 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
The best thing you can do is make sure the inside of the I/C is clean along with all the light filters and lenes. Also make sure the fluorescent green backing paint is in good shape
Old Oct 22, 2015 | 08:34 PM
jet-tech's Avatar
jet-tech
Gregg
Check out this website and compare. Make sure you compare not only amps but D.hours. you don't won't to buy a brighter light that has only 50 D.hours. Tim
http://www.donsbulbs.com/cgi-bin/r/b.pl/1816~usa.html
Old Oct 23, 2015 | 12:36 AM
Grampy's Avatar
Grampy
You can use brighter LED bulbs for instrument lighting. They work great. Search for posts.
Grampy
Old Oct 23, 2015 | 10:57 AM
jet-tech's Avatar
jet-tech
Grampy
I tried some of those LED, the ones I purchased would not dim. And I thought they were to bright. So I installed 1416, two times brighter than 1816 and will dim. The glass is bigger but it will fit in the whole. Here is data on the 1416.
http://www.donsbulbs.com/cgi-bin/r/b...-electric.html
Old Oct 24, 2015 | 12:44 AM
rnixon's Avatar
rnixon
C2 of Year Finalist (appearance mods) 2019
I used [4], 64111 halogen bulbs , placing them in the 4 lowest sockets in the cluster, [small gauges, tach & speedo] and [2] in the clock mount, for AC & heater controls. Would not recommend using them in the clock,even with orig. movement [ plastic gear on reset] Additional Amp. draw is negligible, I was pleased with the result, there was just enough extra illumination for the Tach & Speedo. an the small gauges and AC controls are nicely illuminated
Old Oct 24, 2015 | 01:16 AM
vetsvette2002's Avatar
vetsvette2002
Veteran: Marine Corps
St. Jude Donor '13-'14-'15-'16
is 64111 the part number of which vendor/mfr?
Old Oct 24, 2015 | 01:36 AM
Grampy's Avatar
Grampy
My LEDs do work with the dimmer. LEDs can be much brighter and use less watts. Last forever and won't rust, bust, gather dust or melt in your pocket or so they say.
Grampy
Old Oct 24, 2015 | 01:52 AM
rnixon's Avatar
rnixon
64111 is bulb ID number,various mfr.Sylvania, Osram and others, many dealers, even Wal-Mart ,Google 64111 halogen bulb an pick source. 5 watt, 12 volt, BA9S base, 6.7cp , 1816 was 2cp. discontinued 1817 was 3cp. To be on the safe side [heat] I only used them where indicated, Installed 2 years ago, result was everything I wanted
Old Oct 24, 2015 | 12:13 PM
jet-tech's Avatar
jet-tech
Here are the specs on the 64111 bulb. If you don't drive your car very much it would be a good choice, it's a lot brighter then the stock 1816 bulb. Life of the 64111 bulb is only 200 hours. The 1416 is 1000 hours and is also 8cp.
http://www.donsbulbs.com/cgi-bin/r/b.pl/64111~usa.html
Old Oct 24, 2015 | 12:26 PM
7-11vette's Avatar
7-11vette
thanks for all the info will try the 1416
To lights in dash
