Idle issues
Old Nov 8, 2015 | 09:57 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
Originally Posted by Ktholin
I checked the vent tube and it is not plugged. I know it's weird, but true. The moment I disconnected the vent tube it ran great. Is there a vacuum, albeit slight, that the air cleaner pulls on the tube and could that have an effect? Is there a reason it is connected to the air cleaner?
I'm going to sleep on this one. It's just backwards.
What happens when I disconnect the Balance Tube at the Fuel Meter is that turbulence from the engine fan swirls around the opening in the side of the Fuel Meter and plays havoc with a stable idle air/fuel mixture.
The reason the Balance Tube connects to a port in the air cleaner is that is where still-ish air at atmospheric pressure can easily be had.
Jim
Old Nov 9, 2015 | 08:17 AM
MikeM's Avatar
MikeM
Jim
The same thing can happen if the air meter is left open with no air cleaner.
Suppose his air cleaner is obstructed?
Old Nov 9, 2015 | 09:29 AM
jim lockwood
I just don't know. It's an interesting discovery, but I suspect it's a side effect of the real problem more than a problem in and of itself.
I have good reason to believe the FI unit was not properly calibrated after it was rebuilt.
If I'm right, the experiment I suggested which involves disconnecting the vacuum line to the Enrichment Diaphragm ought to result in a stable, albeit somewhat rich, engine idle..... with the balance tube installed, of course.
Jim
Old Nov 9, 2015 | 10:52 AM
MikeM's Avatar
MikeM
Jim
You are suggesting it's too lean at idle?
Sounds like it could be.
Old Nov 9, 2015 | 04:13 PM
jim lockwood
Yes, but not just at idle, at all RPMs. His unit was NOT calibrated by the rebuilder so the Economy Stop could be rich or it could be lean, but it is almost certainly wrong (and I'm betting on lean).
The fact that the engine speed picks back up once idle vacuum drops low enough for the Ratio Lever to swing to the Power Stop is a big clue that the unit is lean. Another is that Keith says the Idle Fuel screw has little effect, except that he can stall the engine when it's screwed all the way in.
Being a 4800 unit, there could be other conditions causing a lean condition besides just lack of calibration.
In a 4800 unit, the idle boost circuit is configured differently from ALL later units. There could be a piece of trash blocking an orifice. A restriction in the main diaphragm "T" fitting could be an inappropriate size. Who knows, one of the valves in the Cold Enrichment housing could be leaky, causing a loss of Main Diaphragm signal.
None of these potential problems are suitable for a Do-It-Ur-Selfer to diagnose, so I'm just focusing on calibration for now.
Old Nov 9, 2015 | 05:28 PM
Ktholin's Avatar
Ktholin
Ok, Jim, I ran the experiment by disconnecting the Vacuum tube from the Enrichment Diaphragm while leaving the balance tube connected. As expected (I think) the idle ran smoothly. Ratio level rested against the Power Stop. I also disconnected the Balance Tube while the Vacuum Tube was disconnected and it still idled smoothly but at a slower rpm.
In summary, with either the Balance Tube or the Enrichment Vacuum Tube disconnected, engine idles smoothly. When both are connected, idle is poor.
I have attached a couple of videos. I don't know if these will help, but they illustrate the two above points.
Keith
Old Nov 9, 2015 | 09:15 PM
jim lockwood
Keith,
The two videos got the point across very nicely. I thought the engine sounded pretty good when it got the richer mixture.
If you have a shop near you with a chassis dyno, I'd suggest you take the car there and I'll walk you through the calibration process..... which I think that FI unit sorely needs.
Alternatively, if you have a friend with a wide band air/fuel gauge you could borrow, same offer: I'll give you instructions on what to do.
Lastly, if you don't have access to either of those resources, we can attempt approximate calibration by using the tried-and-proven, if somewhat inaccurate, Seat-Of-The-Pants-O-Meter.
Jim
Old Nov 9, 2015 | 09:24 PM
Ktholin's Avatar
Ktholin
Keith,
Jim
Thanks, Jim. As alway, I really appreciate your advice and offers to help. I think I'll look for someone locally who can help me with the calibration. I'll keep you posted.
Keith
Old Nov 9, 2015 | 10:41 PM
jim lockwood
Keith
Glad to help, Keith. If you look for someone to just do the calibration, be sure that individual has actual FI experience and understands that there is a rigid sequence in which the calibration steps must be performed.
Jim
