ethanol gas problems?
Old Nov 18, 2015 | 09:18 AM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
I've been using (not by choice) E10 for oh, maybe 20 years, and have not had any problems, no carb problems (other than heat soak perc), no electric fuel pump problems, no mech fuel pump problems.
I did change all my rubber fuel lines over to SAE J30 R9 fuel injection line.
Doug
Old Nov 18, 2015 | 11:22 AM
MikeM's Avatar
MikeM
There is a poll going now, "do you carry a spare set of points".
Maybe you could start a poll about, "do you carry a spare electric fuel pump and carburetor if you use E 10?
Just wondering.
Old Nov 18, 2015 | 12:47 PM
tuxnharley's Avatar
tuxnharley
Naw - I'll leave that new poll to you, Mike!
Old Nov 18, 2015 | 12:49 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
And guys I started this thread to be a joke. I am having zero issues related to the type of gas I'm running.
Old Nov 21, 2015 | 12:40 AM
GDD's Avatar
GDD
Lubricant - preventing the moisture in the ethanol from decaying pot metal in carbs, FI, etc. We have had several speakers at our club events who suggest anywhere from 1 oz per gallon to 1/2 per gallon of unleaded. I use 1/2 oz per gallon every other time I fill up in both my fuelie and dual carbs.
Old Nov 21, 2015 | 12:45 AM
GDD's Avatar
GDD
I thought you were serious because I have seen carbs totally ruined by ethanol. Maybe it is the California mix or maybe not.
Old Nov 21, 2015 | 06:27 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
Please post pictures of those ruined carbs as I have run ethanol-laced fuel in my 6 C1 WCFBs for the past 8 years and my 1 C2 WCFB for 2 years with no ruination. Also in my boat, jet ski, pressure washer and weed whacker... I'm willing to learn.
Old Nov 21, 2015 | 07:14 AM
Nowhere Man
What did you see in my pictures that suggested that my carb is ruined? By all accounts I am fair from a expert on carbs. But I see nothing, no discoloration, no junk in the carb, and ect. Inside the front bowl and main body that would suggest a problem.
Old Nov 21, 2015 | 11:44 AM
427435's Avatar
427435
Once, in 55 years of dealing with engines in lots of different machines, did I find a carb messed up. It was in a boat prior to the days of E10. Evidently I had gotten water into the system and, after setting over winter, the fuel bowl was full of crud.
After that, I would put a bunch of "Heat" into the fuel tank and run the engine for a while before parking for the winter. Heat, of course, is nothing but alcohol. Once E10 came along, I stopped doing that too.
No worries man!!
