1960 powerglide
After determining my car came with a powerglide, I began looking for this transmission. After reading topics about this part I thought it would be an easy project. I was wrong. A lot of power glides were changed out to a three or four speed standard to achieve the performance a glide could not give. I don't think a lot of those powerglides were placed up on a shelf somewhere for future use. I would guess most of them ended up at some junk yard. I originally started out trying to convert a passenger glide to a vette glide. Trying to find that tail shaft and housing is like trying to find the holy grail. Also anybody that I talked to had a different story on how to do it. It just seems there is not a lot of good information when it comes to a 60 corvette powerglide. Still trying to find info and pictures of correct 60 linkage. Yes there are a few of these trannys for sale on the net, but the prices are out right rude. Then you have to still buy all the extra parts that should be on it in the first place. Eventually I found supposedly a 1960 corvette powerglide 7 hours away. When I arrived I noticed there was not an X on top to determine that it is a vette glide and not a passenger conversion. Please correct me if I am wrong on the X identification. I figured all that way at least I got the SHAFT and correct housing.
Determing value on these cars are based on the following.
1) Does the car come with options, the powerglide was an option.
2) Is the powerglide tranny difficult to find and complete, I think so.
3) If you are looking for a 3 or 4 speed standard, there are a lot out
there.
4) A powerglide is usually preferred by a woman driver (wife), that in its
self should drive the price through the roof. Most women don't want or
need to drive a standard.
I am tired of listening to the announcers say this powerglide will hold the
price back as it goes across the block. It's time we powerglide owners
start getting a little more respect. Okay I'm done ranting.
Happy Newyear to all
Katch
P.S. Yes I know, I forgot to mention H.P.
One of the most difficult parts you will need to source will be the starter relay that mounts to the fire wall on the passenger side. Mary Jo sells a 4 wire relay that will work when you get tired of looking. P.S. yes I have an original!
Katch
What is this starter relay, and why did a PG car have one?
Doug
all works good . The safety switch is really rare. Plugged the safely switch in to stock harness.
Don't remember seeing this relay anywhere.
Katch
I've been wrong before though.
Richard Newton
Restoration Fun
The stamped code on the engine would be the only place to determine engine option. FH, FG etc.....if it were the original engine.
Other hints to rtell if originally auto...screw holes for relay on firewall, wires different for auto cars, clutch tower not present or if present, probaly a poor job of attachment. firewall, FW insulation is different than for auto vs manual, re hole in place ornot for clutch rod, etc
Richard Newton
Restoration Fun
Katch
Katch
The absence of a clutch tower and firewall clutch rod hole, as well as the different main wiring harness (neutral safety switch) are huge tells.
Paul
there.
Katch
Pierre
The '56 PG is a cast iron unit like my '58. The aluminum cases began in 1962.
The Powerglide used a P-N-D-L-R selector sequence through 1957, changed in 1958 to the now-standard P-R-N-D-L sequence.
It'll be interesting to see what the OP finds with his car.
Richard Newton
My Interior Project
I just installed the correct brackets for my rear reflectors. When the car was painted about 50 years ago the brackets were never replaced. I didn't know about them until about 6 months ago.
Richard Newton
