engine size question
Old Dec 28, 2015 | 10:56 PM
sby's Avatar
sby
1st Gear
Default engine size question
What's the largest corvette engine that can fit in a 1967 Corvette without altering the car
Old Dec 28, 2015 | 11:31 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Hmmmn...OEM spec...or "looks the same and can bolt in"?
You can easily drop in a 540-555-565-582 cube engine based on a short deck aftermarket block.
JIM
Old Dec 29, 2015 | 11:26 AM
Bruski's Avatar
Bruski
A good friend of mine blew his 427/435 up. Broken cam and 3 rods thru the block. He dropped a 502/502 in with few fit problems...
Old Dec 29, 2015 | 11:54 AM
Easy Rhino's Avatar
Easy Rhino
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
Assuming you mean largest as a function of cubic inches, not horsepower:
The 427 that was available in the 1967 is a Chevy Mark IV engine, typically known as the Big Block or "Rat" engine, is a standard deck height engine. Any engine based on that, as said above, should be an easy bolt in, dependent upon using an intake that is not too tall.
I have doubts that a taller deck height of the same big block engine would fit, based on the intake gets taller with the taller deck height.
The LS engine series are small-block based and are frequently seen in mid-years as well.
No idea on non-Chevy engines, but you did say "largest Corvette engine."
Old Dec 30, 2015 | 02:06 PM
Avispa's Avatar
Avispa
Just be aware that GM Gen V and Gen VI big blocks do not have provisions for a mechanical fuel pump or clutch bellcrank ball stud. GMPP does sell a bracket that bolts to the bellhousing for the ball stud. Aftermarket blocks like World Castings Merlin will fit everything from a Mk. IV big block. OEM spec, you can drop in a 496 (.060 over, 4.25 stroke 454).
To engine size question
