fuel sensor help
Old Jan 4, 2016 | 12:36 PM
old68's Avatar
old68
Default fuel sensor help
my sensor is way off , seems like its wound the wrong way, can anyone recommend a vendor for a correct replacement?? dont want the same problem, thank you!!
Old Jan 4, 2016 | 01:48 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Are you referring to the sending unit in the tank? I don't know who makes them or which ones, (assuming more than one maker) are good or bad. It's possible your gas gauge is going bad, or have you checked all the connections. Dennis
Old Jan 4, 2016 | 02:16 PM
old68's Avatar
old68
Default yes, sending unit
yes , its the sending unit, looks like a cheap chinese unit in there
Old Jan 4, 2016 | 02:41 PM
MelWff's Avatar
MelWff
have you used an ohmmeter to verify your conclusion? You should have about 45 ohms at half full and 90 ohms totally full and zero at empty. If it fails Willcox can supply a new one.
http://repairs.willcoxcorvette.com/1...st-66-67-only/
Old Jan 4, 2016 | 05:57 PM
old68's Avatar
old68
Default didn't do that
did not do that, however gauge reads just under 3/4 at empty and just over 3/4 at full
To fuel sensor help
