Rust Experiment
Rust Experiment
FWIW, I'm doing a chemistry experiment to clean rust.
I mixed 9 parts water to 1 part molasses and am soaking the attached very rusty cigarette tray mount for two to three weeks.
I'll take pictures as things progress. Ideally all of the rust will be gone after the process.
The molasses is from Tractor Supply Company, where they sell it in gallon bottles for livestock.
The idea came from:
-- Joe
The idea came from:
-- Joe
Dan Laxuma (01-26-2016)
This looks like a killer idea...hope it works like the video shows...
Well, at least it oughta smell good - better than the vinegar technique!
As stated previously, it works -- well-- and it won't take two or three weeks, but should look better in a matter of days. I prefer it to electrolysis. Do not leave cast pieces, like vibration dampers, in there any longer than needed to remove rust.
olasses
The idea came from:
-- Joe
The idea came from:
-- Joe
Received 5,053 Likes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
I'm waiting for the "after" pic - the piece will be totally covered with 20,000 ants!
My garage is not heated, but it maintains about 40* F this time of year (or warmer, depending on the weather). So, ants should not be a problem.
-- Joe
I have used this method many times & it works great. It won't take off grease or paint but the rusted areas will look like new steel.
It works best when warm. I usually do it in the summer & leave it out in the hot sun. 1 to 2 weeks.
The first time I used it was on a model A hood. Worked great between the louvers & cleaned the hinge knuckles out perfectly.
Impressive! Since the part to be de-rusted seems to have to stay submerged, I'm guessing this does not work well on a frame - say, repeated applications with a paint brush or spray bottle. Maybe an unused swimming pool would work?
-- Joe
Never heard of molasses for rust removal. You learn something new every day.
I was thinking of trying something like that. The downside would be it's in the garage and these western New York winters are not conducive to hosing it off. For example, 17 degrees outside now, probably 40 in the garage until I fire up the heater. hlvette notes it works best when warm, so maybe this is better off postponed till about May.
-- Joe
Done this years ago using a 55 gallon barrel filled half way. Works great for small parts with tight areas. The part must be completely degreased for max effect. Best done warm because it gets too thick when cold.
Here is generic evaporust. $60 including shipping to make 16 gallons or $5 a gallon. Also tried another generic rustdepot. Both work the same as evaporust $25 a gallon. It is also better in that you can mix up more concentrated and it works faster. I also use ospho but it leaves a residue. I got into using evaporust when I needed to free up a frozen 36 glove box hinge. Ospho wouldn't have worked but evaporust did very well! It is still sort of a specialty product as it is not good at taking off really heavy rust. I soaked my 49 woodie rear hatch in evaporust and it didn't make much difference. The ospho ate some holes in the hatch but it only eats rust after all! I'll have to patch the holes.
I have the bin that the parts are soaking in out in the garage (there is a bit of a smell, but it's not too bad -- just enough to warrant not doing it by the furnace).
-- Joe
-- Joe
OK - one week in the cold garage soaking in the mixture resulted in these pics. Paint is still on and has some of the molasses coating but looking good.
Only a quick clean off of the molasses coating, but nothing beyond that.
