Rear Wheel Bearing Question
Hi All,
I have just replaced the trailing arms on a 66 C2 with brand new ones from Zip which included the bearings, parking brake shoes and rotor etc.
I replaced them because of play in the bearings.
Having finished the job now, I have noticed when the rear wheel is held at 12 & 6 o'clock there a small amount of movement when the wheel is pulled back and forwards. This seems to be movement in the wheel bearing.
Is this normal or should there be no movement at all.
Thanks Phil
Thanks Phil
Are you sure it's not movement of the yoke in and out of the differential?
Is that yoke movement normal? or would the strut rod not allow that movement?
Phil
Received 2,127 Likes
The movement is normal on both sides! Dennis
I have had another look at the wheel movement and it seems to be that the strut rods (these are ones I bought from VBP with the Dom rod ends and only driven about 2000 miles with them) are moving back and fowards on the shock lower mount. It seems there is movement between the eye of the Dom end and the shock lower mount.
Has anybody else had this problem and is it critical to have no movement at that point.
Thanks Phil
Thanks Phil
Thanks Phil
Thanks Phil
veeeight (01-21-2016)
No experience with aftermarket struts but there shouldn't be any movement at that connection - that will allow the camber to wander around under cornering. As said above - if you don't have at least a small amount of movement of the side yokes in and out of the differential - yours is probably the only one.
When I had the trailing arms off the car and the drive shafts disconnected I did have movement of the yokes in and out.
Thanks for your help.
Phil
