Removing lower ball joint from the A-Arm
On a '66. Got the side nut/bolt off and the top nut under the grease zerk. Question is: is it pressed in to the A-Arm and I just need to press it out?
Thanks in advance
Thanks in advance
Fastens on the a arm in 3 spots. A rivet (or bolt if it has been replaced) on each side and nut on top. I take a large brass hammer so to not mushroom the bolt and smack the top and it pops out. Might be some rust or crud glueing it in.
Tigershark3 (02-07-2016)
On my 72, the uppers popped right off with a pickle fork. The lowers gave me fits. Finally bought the ball joint tool set from HF, that in conjunction with an impact wrench, and got them off. I don't know why the lowers are more problematic.
Hope you have a 'chain' wrapped around the A-frame or a spring compressor to keep it from killing someone...
or you could use some all thread/nut/washers to keep it in place..
This is what i made/used...along with a floor jack..
:::EDIT:::
Should have mentioned where this goes...remove shock and insert it from bottom up and put nuts/washer on then do the bottom...
:::EDIT:::
:::EDIT:::
:::EDIT:::
