65 350 Distributor
65 350 Distributor
I opened my distributor cap for the first time and found this blue rotor. Tried finding info on it but there seems to be little. Lots of small white buggers inside the distributor cap so its time for a new cap, rotor, points, etc. Any suggestions would be very welcome!
Steve
Steve
Rotor
That's a high performance rotor made by Standard Motor Products. I have their cap & rotor on my engine. They should be available at any auto parts store that sells Standard---Good Stuff !!!
RON
Received 1,877 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Doesn't look like you have points anymore either. Not much to do in there other than make sure advance mechanism is working correctly.
JIM
JIM
Ron, thanks. I just checked and both Summit Racing and Rock Auto carry them!!!
Jim, thanks, I was dealing with other stuff today so just took the picture and moved on. Will pull the rotor tomorrow and see whats under there.
Received 1,843 Likes
After you pull the rotor, I believe I'd put it back on there. I don't see anything wrong with it.
Received 1,534 Likes
Nuts?????
Steve
Steve
I'm convinced.
It appears I have a Standard Products cap and rotor with a Mallory ignition module. And I don't believe I've ever owned a reluctor wheel before! Who ever put it together was having some fun! It all seems to be functioning OK; I just opened it up to do normal maintenance but since its all electronic I'll take your advice and clean it up and leave it be for now.
Thanks all for the input!!
Steve
Received 2,127 Likes
As said before, it's a Mallory Unilite and they are very reliable. In order to protect the unit, get the Mallory Surge Protector MAA 29351 $55 from Summit. It plugs inline per directions. Dennis
