63 steering damper
Old Feb 20, 2016 | 11:05 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
Default 63 steering damper
Are the repros worth a hoot ?
The shaft on mine is dinged up and the rubber bushing is cracked and brittle. One way or another it has to be addressed
Old Feb 20, 2016 | 01:58 PM
tbarb's Avatar
tbarb
Frank,
Why not put power steering on that car..
Old Feb 20, 2016 | 05:32 PM
rfn026's Avatar
rfn026
He already got dinged for the A/C.
Why not just got all the way.
Seriously though you might want to talk to some of the guys that rebuild shocks.
Richard Newton
Old Feb 20, 2016 | 05:54 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
I have run my car, before P/S conversion for well over 20 years without it. Never made any difference. Dennis
Old Feb 20, 2016 | 07:11 PM
USMC 0802's Avatar
USMC 0802
Veteran: Marine Corps
USMC
Frankie,
I got mine from Bair's Corvette and installed it two weeks ago. I think the one I replaced was the original one and it was nasty. The replacement fits perfectly and does what it's supposed to.
Had it to to a tad over 100mph (on a closed course, naturally) and it's rock steady.
Post with my original one is here:
https://www.corvetteforum.com/forums...with-pics.html
We took it out today for a 50 mile highway blast to get some heat in it...
Good luck!
Old Feb 21, 2016 | 06:59 AM
Frankie the Fink
Army
I was offered a complete 63 power steering system for a 63 by a forum member; and it would pass judging. I've never felt the need for it in the 63 or the 61...
Repro damper is on the way and I'll look into getting the original rebuilt.
Old Feb 21, 2016 | 07:09 AM
jfr's 63swc's Avatar
jfr's 63swc
I will interested to see how the rebuild goes - mine could use some new rubber. I have looked and not only can I not find replacement rubber, I am not sure it is a do it yourself job!
Good luck and keep us posted!
Old Feb 21, 2016 | 02:05 PM
tbarb's Avatar
tbarb
I installed P/S unit off a burned 63 convertible on my 63 coupe and I really like the assist. Also installed one on my 67 and I feel it's the best add on you can install and maintain the factory look.
Most times you can pick them up at the Carlisle show fairly reasonable.
Old Feb 22, 2016 | 05:40 PM
BADBIRDCAGE's Avatar
BADBIRDCAGE
Frankie:
In my experience the remanned steering dampers work fine. As far as your shaft beong dinged up if they can polish the shaft smooth you shouldn't get hit for a core charge.
To 63 steering damper
