Optima battery garbage?....or..?
My 69 Camaro has one purchased in '04. My 240Z as well. I have (3) installed in jeeps that were bought in '04, '05, and '06 respectively. I have a couple of Blue Top combination batteries bought in '11 that are combination deep cycle/cranking and one yellow top marine. I think total count was thirteen with half of those over 10 years old.
The secret to having them last IMO is not trickle charging but disconnecting them from the rest of the car when it is sitting. Can't do this easily on late models, but anything with a carburetor a non-issue. Most of my vehicles sit for weeks if not months at a time on occasion and start right up after the battery is reconnected, no jump required.
The yellow top is the only one I have had fail at this point. It was purchased in '05 and made it to '14. I will say that when the first ones were bought at Sam's for less than $100 they were an EXCEPTIONAL value. If the newer ones make it 10+ years as well they are still a tremendous value compared to the lead acid batteries. Oh, and terminal corrosion because of out gassing minimized exponentially.
Kill me now...
Lab tests also don't take specific applications into consideration. Does someone with a 2000 Ford Taurus have the same concerns about a battery as someone with a show quality C2? A lab test won't tell you how easy or hard it is to get warranty service on your battery. Companies can manufacture batteries that perform great in a lab test, but don't work as well in the field or vice-versa. Which one would you rather buy? Most folks will look at Consumer Reports results as a useful tool, but not the final word in making a purchase decision. If that were the case, Chevrolet might not sell many Corvettes.
fargon, I apologize if I wasn't clear in my previous post regarding charging our batteries and I'm sorry to hear about the issues you've had. Most chargers will charge and maintain Optima batteries just fine.
Frankie, the purpose of the video was to let consumers know a variety of common ways they can recharge their batteries. We understand the parallel charging technique might be too complicated or intimidating for some folks to attempt, which is why we suggest those people take their battery to a professional, who can charge and check it for them.
Jim McIlvaine
eCare Manager, OPTIMA Batteries
www.instagram.com/optimabatteries
I do keep it - as I do ALL my non daily driver car's batteries of various types and brands - on a maintenance/"float" charger when not in use.
That seems to be the key to long battery life, even more so than disconnecting.
I sure do like not having to replace the battery in my '67 under the expansion tank on a regular basis!
While we do sell our own chargers, most battery chargers will work just fine to charge and maintain our batteries. We do suggest avoiding “gel” or “gel/AGM” charger settings or any charging rates that exceed 10 amps. Contrary to Internet speculation, there is no gel in our batteries and all batteries are vulnerable to improper charging. In fact, some other brands will void your warranty if you use a charger that doesn't meet the exact charging parameters listed in their warranty (we don't do that with our warranty). Some load testers will have AGM or Optima-specific settings, but properly-trained battery professionals will be able to correctly identify and load-test a battery. Load testers that don't have specific settings for Optima or other AGM batteries generally won't require a different testing method for those batteries.
There are a lot of battery manufacturers (and even more brands), although most batteries produced for this market are manufactured by one of three companies, including Johnson Controls, which owns Optima batteries. However, we manufacture all of our own batteries in our own facility and they are the only batteries produced there. We never re-spec or re-brand our batteries for any of our retail partners. The quality of our batteries is also excellent and the batteries we are producing today are the best we have ever made. Spend enough time reading conversations about batteries and you'll find positive and negative reviews on every brand.
As for warranties, they are largely a function of marketing and not necessarily indicative of product quality. If any battery fails because of a manufacturing defect, it is likely to do so well within the first few weeks of use, if not the first few days. Beyond that, battery lifespan is largely connected to how it is used and maintained.
Bill, I'm sorry to hear about the problems you had getting warranty service. All of our warranties are serviced by the original retailer, but in the case of situations where customers have moved or retailers have gone out of business, we can usually make accommodations for warranty service near their current location, if we have a battery and a proof of purchase. I asked our call center for the transcript of their conversations with you and they indicated they had none attached to your name, so perhaps they didn't have that information. In any event, I apologize for that lack of service, as that is not typically how those situations are handled.
The parallel charging technique DanielJ described is also explained in this video.
Jim McIlvaine
www.facebook.com/optimabatteries
Jim McIlvaine
http://www.odysseybattery.com
I think it can also be assumed that some people have battery problems and some don't, regardless of battery brand. Fix the car before blaming the battery.
Jim McIlvaine
Jim McIlvaine
http://www.thedieselstop.com/forums/.../215667?page=1
Jim McIlvaine
Jim McIlvaine
The video says plant is in Monterrey Mexico. Good video.
It's been drained all the way, probably a couple times, and always came back with no problems.
But, the Optimas don't fit well with the stock battery hold down on the midyears. Initially, I added some spacers, but eventually replaced it with a polished billet aluminum piece made just for the Optimas, and this gives a nice fit. These are available through the "Tri-Five" group.
