As important as the font, if not more so, is that fact that the numbers and "H" pattern are embossed (debossed?) in the metal plate. Most, if not all, reproductions are basically a silk screen on top of the metal surface...all of these will fail flight judging
Well if 1967 is the same then this is what the JG states: "The shift pattern is de-bossed and silk screened in black on a small brushed aluminum plate indented into the console behind the shift lever." Here is a photo of mine, sorry about the shifter shadow, but the de-bossed areas are apparent, and you can feel this when touching the shifter pattern area
The first shift indicator plate in your post appears to be for a 63. (unique to that year) That plate was quite different than the one for 64-67. The 4-speed plate was available for 63 but never available from GM for 64-67.
You are correct, it is on the internet as a 63. I am off to $ee if some one is $elling one!
The NOS ones are not correct either as the font on those are thicker than OEM plates. This is a good example of how NOS does not necessarily mean that it is the same configuration as an assembly line part.
The one in the center looks like a 63 (only) plate. The 63 plate originally did have fatter characters and pattern.
That is correct. We're not comparing apples to apples here. We need to exchange the center one for an NOS 64-67 plate. I think I have one in the box at home, but I'm in FL at the moment. Bill
I don't think there is such a thing as an NOS 64-67 4-speed indicator plate. I've never found one listed in any old parts books.
The only one that I ever found in parts books was for a 64-67 with 3 speed.
The part number for the 4-speed indicator is probably shown in any 64-67 AM but not in GM parts books or price schedules.
