Gasoline
Old Mar 6, 2016 | 12:02 PM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
Originally Posted by MikeM
I can't prove this but one danger of running old gas after the light stuf is gone is that thick stuff that is left might just get sucked down the intake valve stem and stick an intake valve. The gas would have to be awful stinky though.
I have seen a case where really old gas glued all the rings in the ring grooves of the pistons with a heavy brown varnish, causing loss of compression and requiring motor rebuild. The cyl walls weren't damaged, but the rings got stuck in their most compressed state.
This particular car was typically run for several miles every year (start up, drive a mile every couple months), and I don't think the gas was changed for several years. I saw the pistons at a rebuilders shop, he told me the story about the car.
Doug
Old Mar 6, 2016 | 12:41 PM
SWCDuke's Avatar
SWCDuke
The referenced article is technically challenged, and I didn't see anything about a "shell engineer" and who is "Richard Newton" and what are his credentials?
Let's start with this quote:
"Gasoline is a highly refined substance with complex molecular bonds. Over time, these bonds break and the fuel reverts back to an earlier unusable state. As the molecular bonds break, the octane rating falls to the point where the gasoline is no longer able to produce the energy required for effective internal combustion."
What really happens is that over a long period of time - usually several years - the HC molecules slowly oxidize and eventually form gum and varnish, and this reaction rate increases exponentially with temperature, so the cooler the storage environment the better.
Also over time the lighter components, which are also the higher octane components can vaporize, which can lead to harder starting and loss of octane value, and this will occur more rapidly with vented fuel systems, and as with oxidation will progress more rapidly the hotter the surrounding temperature.
Back in the day water at the bottom of the fuel tank could freeze and leave the car stranded - happened to my SWC once circa 1965. There were various products on the market like "Heet", that were basically alcohol, which acts as a cosolvent that allows much more water to mix homogeneously with gasoline so it will be harmlessly consumed by the engine as the fuel is burned off. So, in a way ethanol is good because it takes a lot more absorbed water before the water/alcohol blend drops out, which will begin the corrosion process and often render the engine unstartable.
Oil company engineers that I have talked to have stated that the "shelf life" of gasoline is about one year, but the point was brought up: "What is shelf life". My definition is the amount of time before the gasoline significantly deteriorates is terms of octane or gum and varnish formation, and this is a function of the storage environment -sealed or vented container? Temperature? Humidity?
I think one year shelf life is conservative and may be absolute worse case conditions. As stated by many no problems have occurred with gasoline several years old, but as a precautionary measure I recommend consuming at least one full tank per year and keeping the car in as cool/low humidity environment as possible.
Duke
Old Mar 6, 2016 | 01:43 PM
survivor66's Avatar
survivor66
Duke
So, having both vented and non-vented gas caps, I should use the non-original, non-vented one for long term storage. That makes sense to me. But I have to remember to switch them before running the engine again or I'll experience stalling due to fuel starvation. That's happened before.
Old Mar 6, 2016 | 01:55 PM
rtruman's Avatar
rtruman
Originally Posted by Frankie the Fink
I'm having a fit with vapor lock in the stock 63. Not in the 61 tho that also has WCFBs. Spacers haven't helped. Gonna try non ethanol next.
I had a hell of a time with my 67 327 .
I even wrapped the gas line with insulation .The gas would boil scared the heck outa me . It had a Holly Carb on it may have been the problem it was good after insulation.
Old Mar 6, 2016 | 01:56 PM
SWCDuke's Avatar
SWCDuke
I think '67s had pressure/vacuum relief caps with valves that released at about+/- 2 psi, but I might be wrong.
In any event, if you've had fuel starvation with a pressure/vacuum relief cap, use a vented cap during the driving season and install the pressure/vacuum relief cap during the storage season, which will slow the rate of evaporization.
Don't use a cap that is "non-vented", which means it lacks pressure or vacuum relief valves. That could cause the fuel tank to deform if the pressure or vacuum gets too high.
Duke
Old Mar 6, 2016 | 02:02 PM
SWCDuke's Avatar
SWCDuke
E10 has lower mid-range boiling points than typical straight gasoline, so vapor lock and percolation in the carb bowls can be a problem.
And because the fuel feed line to the pump passes very close to the exhaust manifold, fuel temperatures can exceed 150F before it even gets to the pump, especially in hot weather low speed traffic.
Insulating the fuel feel line to the pump in the engine compartment area can be very effective at mitigating vapor lock and percolation.
Duke
Old Mar 6, 2016 | 02:28 PM
1snake's Avatar
1snake
Thanks for posting Duke. That reference article is full of incorrect information.
Old Mar 6, 2016 | 02:45 PM
MikeM's Avatar
MikeM
I can see a run coming on non-vented gas caps starting any time now. I thought my original vented caps kept fuel just fine for a couple three years.
Old Mar 6, 2016 | 03:13 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
I've found an ethanol-free source not that far where I was buying my regular gas anyway - certainly can't hurt to try a few tankfuls. But I've NEVER had to resort to that in in 35 years of owning classic cars...
Old Mar 6, 2016 | 03:49 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
Bill
Old Mar 6, 2016 | 04:27 PM
USMC 0802's Avatar
USMC 0802
Veteran: Marine Corps
USMC
Running a 30-50% mix of 100LL and Sunoco 93 seems to keep things happy.
I drive my '66 a lot, so gas only lasts a week or two.
This winter the car sat for almost 3 weeks without being driven and it was sad. As soon as the roads were clear of salt and snow, out she goes!
Keep burning it, it's cheap!
Old Mar 6, 2016 | 07:18 PM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Originally Posted by wmf62
Bill
I don't get it. What is this picture supposed to show?
Old Mar 6, 2016 | 07:22 PM
  #33
Frankie the Fink
Army
For some of you youngsters, clipping clothes pins onto a car's fuel lines decades ago was a supposed cure for vapor lock.
Total myth of course.
  #34
1snake's Avatar
1snake
Clothes pins on the fuel line was an old backyard way to help prevent vapor lock.
Old Mar 6, 2016 | 07:25 PM
  #35
Powershift's Avatar
Powershift
Generally followed by replacing the fuel pump.
Larry
Old Mar 6, 2016 | 07:29 PM
  #36
RatDog's Avatar
RatDog
St. Jude Donor '20 thru '25
It is, however, an incredibly attractive look
Steve
Old Mar 6, 2016 | 11:58 PM
  #37
Critter1's Avatar
Critter1
I use only ethanol free in the Corvettes.
I don't even use E10 in my lawn mower.
To Gasoline
Old Mar 7, 2016 | 08:18 AM
  #38
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Originally Posted by GCD1962
With a 10 percent ethanol blend you should replace the fuel in a vented tank about once a month. A lot of people recommend draining the fuel tank and fuel system."
Easiest way to do that is get in and drive it as often as possible!
  #39
71scgc's Avatar
71scgc
Ethanol=Net energy loser.
Carter
Old Mar 7, 2016 | 09:11 AM
  #40
davekp78's Avatar
davekp78
Hey, I wish I WAS a youngster!
