With 370 gears what should my tach be reading at 60mph???
That would depend on which gear and if you have a 4 or 5 speed. If you want a more accurate answer for your car, maybe use a portable GPS to determine your actual RPM vs Speed.
St. Jude Donor '04-'05-'06-'07-'08-'09-'10, '14-'15
Also keep in mind that the older gauge speedo has a 5-7% speed error. They are not that accurate.. This I found out from a "WIllcox" Speedo repair Video.
If anyone needs information along these lines, I still have my first computer purchased in the seventies, made by Iskendarian. It even goes up to 12,000 RPM!!!!!!
