Key Switch Help
Old Mar 8, 2016 | 08:48 PM
Jeht's Avatar
Jeht
Default Key Switch Help
I need some help on removing the key switch? After the threaded nut is loose, what do I need to do for removal? I have inserted an object in the small hole with hopes this would trigger a release mechanism.
Any advise greatly appreciated.
Old Mar 8, 2016 | 08:52 PM
6D2148's Avatar
6D2148
What year?
Frankie the Fink's Avatar
Frankie the Fink
Army
Insert a paper clip into that hole and with the key in the ignition turn the key counter clockwise and pull rearward to remove the cylinder..
Old Mar 8, 2016 | 09:04 PM
6D2148's Avatar
6D2148
Frank is right on but tighten the nut back up first then get tumbler out then loosen nut and remove switch. Chip
Old Mar 8, 2016 | 09:07 PM
Jeht's Avatar
Jeht
Thanks for such a quick response to everyone.
1966
To Key Switch Help
