I have a friend who pulled the distributor out of his 350 and did not pay attention to which spark plug the rotor was facing. Is there a way to look at the rocker arms to tell when it is pointed at the number one cylinder. Or could I use a compression tester in that manner. I know there is a whistle that you can use but we don’t have one. Any ideas would be nice.
Just pull the #1 plug and bump it over (with the coil wire pulled out of the distributor cap) - put your finger on the plug hole, and when you feel air pressure, you're on the compression stroke. When the index mark on the balancer then lines up with the "0" on the timing tab, you're at #1 TDC. You can verify by pulling the left side valve cover - if both valves for #1 are closed (rocker arms even with each other), you're on #1 TDC; if they're not, you're at #6 TDC and need to go another full revolution.
Rotate the engine and watch the #1 inlet valve open and begin to close. Keep rotating the engine and when the balancer notch reaches the tab as the valve is nearly closed, you are approaching TDC #1. Set the notch on the mark to correspond to your initial timing, then install the dist. and rotate it until the points just barely begin to open then back a hair. This should allow the engine to start.
If you can't rotate the dist. to the position that the points just open because of mechanical interference, it is either a tooth off or the drive gear is 180 out. The dimple in the drive gear must point the same direction as the rotor tip.
Whenever I pull a dist. I always set the crankshaft at the #1 the initial timing point - makes it easy to reinstall correctly.
Now here is some good advice. Thanks for all the help. I personally have always set the engine at 1 TDC before pulling the distributor but my friend get a little anxious and forgot to do that. At least we now have a way to check and get the initial start up done. I can certainly adjust it from then. I appreciate all the help.
any time i pulled a dist i always have the rotor tip at exactly 12:00 oclock. that way there is no question where the rotor tip is pointing when you put it back into the engine if you do not turn the engine :chevy
