advice on engine oil
bluzrocker (03-21-2016)
my grease gun took a sh*#...and looks like my (end of grease gun nipple is pretty big)....is there a smaller fitting to get INTO THE 1/2 SHAFTS to apply some grease?? I have seen some discharge nipples smaller around and sort of long and pencil shapped....any ones thought on that?
Of course now I run the solids cuz I got tired of breaking the weaker greasables. If I ever have the shafts out I check the non greasables and they don't need greasing.
u joints
superb reply....I asked if rotating the shafts would open up the joint to the widest point....but YOU are the one who has done it and willing to share it....as I have learned to ask the forum guys... before you start something ....even if its a dumb question...txs
Years ago when I still ran grease-able ujoints I ground the sides of a grease gun nozzle to fit. Rotate the shafts till you get the widest opening. Worked very well.
Of coarse now I run the solids cuz I got tired of breaking the weaker greasables. If I ever have the shafts out I check the non greasables and they don't need greasing.
Why are you guys constantly trying to re-invent the wheel? These cars rolled out of the factory 50 years ago with 30W.
I buy the cheapest, best quality 10W-30 out there... change it every 3000 miles and have never had a single problem.
Drive it... don't over-think it.
Received 1,301 Likes
2022 C1 of the Year Finalist - Unmodified
2021 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
Ken - normally I'm with you on the "don't overthink it".. but realize that 10W-30 is not the same as it used to be. Stuff (zinc and phosphor) have been been lowered/removed because modern engines don't need it. Lots of old threads to search on this.
Not sure I understand the correlation between "cheapest" and "best quality"............ ???
Owner 1964 Corvette
I have read everyone's responses on this thread and other threads about engine oil plus read @SWCDuke 's informative article. Though there is some variety in the opinions on best engine oil, most people seem to go with 15W40 viscosity. The info I can't find anywhere is why are so many people going with 15W40 even though GM originally recommended 10W30 for our C2 engines? Is it a matter of convenience because it is difficult to get 10W30 with the CJ-4/CI-4 service category, or is 15W40 now better than 10W30 for some reason beyond the service category designation? Thanks to anyone who can clarify regarding this aspect.
10-30 was common in the 60s. 15-40 is common now.. We use 15-40 because it's what's out there.
The label is different and the price has gone up, but this is still the stuff to use.
The following 2 users liked this post by 65hihp:
jim lockwood (05-15-2024),
Scott11 (05-15-2024)
Owner 1964 Corvette
Thank you, @65hihp . I bought some yesterday, and this question re-emerged in my mind since the current labeling says "Heavy-Duty Diesel Oil. Low Emission Diesel.", which got me thinking why everyone is recommending this. It seems to be the thing, though!
Just for additional thread reference, here is the current label (currently priced at $11.67 per gallon):
Walmart SuperTech 15W-40 engine oil
Any good 10-30 regular oil or 10-40 mid summer. Then add 1 bottle of Zdd at every oil change.
It works as my 1980 truck has over 400k miles on it and runs great, with no rebuilds. Also run it in my 67, 71, 72, 85( worked) , but not the C8.
Keep an eye on diesel oil as they have been dropping the additives due to DEF.
