63 shift pattern indicator
Mar 23, 2016 | 08:48 PM
4th Gear
how hard is the shift pattern indicator on my 63 to change
Mar 23, 2016 | 08:53 PM
2015 C2 of Year Finalist
Gently pry it off. There is a small amount of adhesive holding it on. But be aware the repo ones differ then original in appearance
Mar 23, 2016 | 09:05 PM
Clean off the adhesive that remains on the console before putting the new one on.
Rick
Mar 23, 2016 | 09:41 PM
Quote:
Originally Posted by
Dud2016
Very Easy......
There are 4 tabs that pass thru the console and are bent over.
You need to remove the console to access the underside.
There is no adhesive.
Mar 23, 2016 | 10:36 PM
If you mess it up i have a "63 NOS" one still in the box...
Mar 24, 2016 | 10:29 AM
Rich Yanulis
Very Easy......
Thanks for setting the record straight. I was thinking of my 67 shift pattern plate.
Mar 24, 2016 | 11:03 AM
This is another of the "one year only" parts used on a '63.
Mar 24, 2016 | 10:26 PM
Rich Yanulis
You are a smart man, thank you. It is so easy to forget the "63 only" parts.
Rick
Mar 24, 2016 | 10:30 PM
ricks327
Rick
Yes that is true one too many for non 63 owners to remember
