60 Odometer and tachometer
Old Sep 3, 2002 | 10:57 PM
Jaxhome's Avatar
Jaxhome
Default 60 Odometer and tachometer
Both the odometer and the tachometer go wild if I hook up the cables to them. (Cables are new) Is there an easy fix on these or do I need a pro?
Old Sep 3, 2002 | 11:03 PM
62fuelie's Avatar
62fuelie
Default Re: 60 Odometer and tachometer (Jaxhome)
Have you lubed the new cables? If not, the cables work best with a special graphite based lube available at most auto parts stores or car dealers. This may not be your only problem, but dry cables will make the instruments bounce.
Old Sep 4, 2002 | 12:08 PM
JohnZ's Avatar
JohnZ
Default Re: 60 Odometer and tachometer (62fuelie)
Every repro tach and speedo cable I've ever bought came "dry", with no lube whatsoever; I pull the core out and lube it with "Kable-Ease" (Corvette Central sells it) before installing the cable, and they run smooth and sweet. Your local auto parts store should also have a graphite-based lubricant made specifically for speedo cables.
To 60 Odometer and tachometer
