Tremec TKO reverse light switch
Confirmed there is power going to the Pink and Green wires by shorting the two and seeing my reverse lights turn on.
From what I can determine, when the TKO is not in reverse the ohms between the contacts on TKO is zero. When put into reverse becomes open circuit. The reverse light switch function of the TKO is reversed?
Just to confirm, I connect the wires from the Pink & Green and TKO and reverse lights went off when in reverse and ON when in neutral/1-5 gear.
Any suggestion or experience regarding this issue? I really don't want to put some type of relay to reverse the circuit.
Thanks in advance for any replies and Happy Easter.
Irwin
