VIN question
Old Apr 6, 2016 | 08:41 AM
ChopperLoco's Avatar
ChopperLoco
Default VIN question
A bit of an rookie here,have not owned a C2 yet...Is there any more info available on a VIN other than if it's a coupe or roadster and production number?
There does not seem to be a trim tag
It is an old 67 race car.
Not on the one registry i found...
Dom
Old Apr 6, 2016 | 08:58 AM
Geralds57's Avatar
Geralds57
2024 C1 of the Year Winner - Modified
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
Dom
Nothing else on the vin other than what you said. The trim tag should be next to vin tag under the glove box. Personally I would stay clear of it unless you plan on leaving it a drag car. Hopefully it's cheap.
Old Apr 6, 2016 | 09:02 AM
ChopperLoco
Yes the trim tag is not there.
It would remain a street/strip car.
So just the one C2 registry?
Hopefully chreap
Dom
Old Apr 6, 2016 | 09:05 AM
ChopperLoco
...My main concern is that the same VIN is not on another car...
Old Apr 6, 2016 | 09:23 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Is it a real GM tag? If so I wouldn't worry about that too much. If it does bother you have the vin ran through the NICB
Old Apr 6, 2016 | 10:32 AM
GUSTO14's Avatar
GUSTO14
Dominic, have you been able to compare the VIN tag to the VIN on the frame? If these two VIN's match, that is a good sign the car is legitimate. If they don't match that doesn't mean it is not legitimate however, but would suggest you need to dig a little deeper.
It is not unusual to find that an "old" race car has been cobbled together from various bits and pieces. It's also not unusual to find a car that looks like and possesses a 1967 VIN is actually less of a 1967 than other years.
If you could post some pictures of the car, some of the folks here might recognize it and be able to provide some additional history on it. Also I believe that the Canadian government maintains a file on all cars imported into Canada. If the car was imported when new they may have info on it that helps allay your concerns.
Good luck... GUSTO
Old Apr 6, 2016 | 11:39 AM
tuxnharley's Avatar
tuxnharley
Does it still have the original engine? Does the partial VIN on the engine match the VIN plate?
Old Apr 6, 2016 | 12:36 PM
ChopperLoco
Thanks Men!
The car has been "back-halved" so some of the original frame is gone.
There is no engine.
There car is on the U.S side at the moment.
So there is just the one C2 registry?
I googled the VIN and came up with nothing.
Old Apr 6, 2016 | 02:37 PM
GUSTO14's Avatar
GUSTO14
Thanks Men!
There is no engine.
Back-halving a Corvette was a quite common practice back in the 60's and 70's when C2's started showing up in the Modified and Gas classes at the drag strip where the IRS just wouldn't cut it. More than a few ended up back on the streets in the 80's and 90's as well.
Pictures might also get it recognized by someone on this side of the border.
Have you seen this one? http://www.63-67corvette.com/
Good luck... GUSTO
Old Apr 6, 2016 | 03:21 PM
65 Pro Vette's Avatar
65 Pro Vette
C2 of Year Finalist (appearance mods) 2019
No trim tag means nothing, unless you want to show NCRS. As a Hot rod or street car who cares as long as the VIN and title are original and not missing. No legal reason you can not remove a trim tag.
Old Apr 6, 2016 | 05:22 PM
ChopperLoco
Thanks Again!
To VIN question
