Bench testing horns
Old Apr 7, 2016 | 01:39 PM
W Guy's Avatar
W Guy
Default Bench testing horns
Is it safe to test original horns using a battery charger? I don't want to get one beep and then fry them. I don't know if the relay in the car has a way of softening the "blow" or not.
Verne
Old Apr 7, 2016 | 01:57 PM
1snake's Avatar
1snake
Verne
No problem but depending on the charger, it may not be powerful enough to make them work correctly as horns typically draw a lot of power. All the relay does is switch the current on and off.
Old Apr 7, 2016 | 05:19 PM
Tampa Jerry's Avatar
Tampa Jerry
Default Horns
You could always use a 12 volt car battery. Ground the horn mount to the neg. side of your battery and use a wire from the pos. side of your battery to the tab on the horn. That should do it. Jerry
Old Apr 7, 2016 | 05:20 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Works every time for me
Old Apr 7, 2016 | 05:21 PM
Randy G.'s Avatar
Randy G.
What?
Old Apr 7, 2016 | 05:49 PM
Nowhere Man
Originally Posted by Randy G.
What?
testing a horn the way Jerry suggested
Old Apr 9, 2016 | 05:46 AM
Randy G.'s Avatar
Randy G.
I was making a joke. Years ago I bought a set of Nathan Air Chime train horns that came off a Burlington Northern and Santa Fe locomotive to put on a tow rig I had. I set the three horn assembly on my work bench and put the air hose to it. It was so loud it blurred my vision. I still have tinnitus in my right ear after that.
Old Apr 9, 2016 | 05:55 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
You can irreparably damage your hearing testing horns while standing nearby...take precautions. Train horns in cars should be outlawed...
Old Apr 9, 2016 | 08:53 AM
59BlueSilver's Avatar
59BlueSilver
2023 Restomod of the Year Finalist
That's another thing I like about my 59, it has a real horn. Not like the wimpy beep horns they have today. You can barely hear the horn in my Tundra, a large full size truck! I would love to have a good set of air horns on it for those who set at stoplights texting.
Old Apr 9, 2016 | 09:13 AM
Frankie the Fink
Army
Boy have you got that right. My 2013 Tundra has the most anemic horn in any car I've ever owned. With all the elderly 'blue hairs' and cell phone maniacs in Florida - it doesn't even faze them when I use it
My restored '63 horns will wake up the dead
To Bench testing horns
