66 underside paint
Old Apr 14, 2016 | 09:51 AM
original76's Avatar
original76
Default 66 underside paint
Please help with paint color on the following parts
drive shaft
shock shafts
rear struts
half shafts
differential
spring
Old Apr 14, 2016 | 10:15 AM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
I don't exactly know, nor do I care what the factory did. If your car is a driver as mine is, paint all of them a shade of gray. If you are headed in the direction of NCRS specs, those members will advise. Dennis
Old Apr 14, 2016 | 10:25 AM
65tripleblack's Avatar
65tripleblack
drive shaft
shock shafts
rear struts
half shafts
differential
spring
drive shaft - natural steel
shock shafts - Eastwood sells medium blue-gray paint for shocks, rear lower shock mounts are natural forged steel
rear struts - natural forged steel
half shafts - natural steel
differential - natural cast iron
spring - Eastwood sells spring light gray paint
Old Apr 14, 2016 | 12:42 PM
65hihp's Avatar
65hihp
as above if you want like original.
if you must paint, then:
drive shaft - silver grey
shock shafts - medium blue-gray
rear struts - silver grey
half shafts - silver grey
differential - silver grey
spring - light grey zinc rich self etching primer
To 66 underside paint
