67 Clock Stem removal
Old Apr 18, 2016 | 12:19 PM
johngandersonjr's Avatar
johngandersonjr
Default 67 Clock Stem removal
Can anyone offer assistance on how to remove the clock stem from a 67 clock?
I have it all apart, but cannot remove the stem. I need to clean it up before putting everything back together. I see there is a spring and a gear on one end, and all that seems to be working.
Thanks!
Old Apr 18, 2016 | 09:39 PM
buns's Avatar
buns
Not sure if this will be of any help, but here are the instructions that came with my conversion kit.
Old Apr 19, 2016 | 08:19 AM
Ron Miller's Avatar
Ron Miller
The only one I ever removed was many years ago, and as I recall was in agreement with step one of the instructions posted; i.e., you must hold the stem with a pair of pliers or such and then unscrew the **** from the stem. That'd be what I'd try . . . . .
Old Apr 19, 2016 | 09:12 AM
johngandersonjr
I have the **** off. I need to remove the entire stem from the clock.
Old Apr 19, 2016 | 09:41 AM
66jack's Avatar
66jack
Looking at the diagram have you removed #6..'nut'?
Old Apr 19, 2016 | 01:02 PM
johngandersonjr
The 67 clock does not have a nut. It has a pressed on gear.
Old Apr 19, 2016 | 01:14 PM
tubman's Avatar
tubman
When you set it back together, please post again so we know what isw necessary. My stem came loose all by itself an I'd like to put it back together. And no, a dab of Super Glue isn't the answer.
Old Apr 19, 2016 | 01:40 PM
johngandersonjr
Once I figure out how to get it apart i will let you know
To 67 Clock Stem removal
