Early 56 generator/exhaust manifold attachment pics
Can someone post some pictures of how the generator is attached to the early style exhaust manifolds
Thanks Sander.
Thanks Sander.
It was my understanding from your earlier posts that you weren't installing the hard to find expensive 2 bolt manifolds. If you did recently purchase a pair you also have to purchase the generator mount mount bracket. It attaches to the front motor mount . There is only one mounting provision on the 2 studs the other is on the bracket . Pictures were posted by member 55copper and on ebay fleagle has a quality reproduction available very limited supply . These early 56's were the first Chevy Hi Perf cars and only @ 700 produced .
1956 Corvette sifter plate for PG or 3 speed was made of zinc not aluminum as most people think , late 56 was aluminum. The zinc plate weighed 3 times the aluminum did .It's one of the rarest plates you'll ever find , worth 100 times more then the cost of aluminum and the character of the numbers is different and deep.
Wow Thanks Roy for all those neat pic's
now i know what to look for or reproduce, the shielding covers do look not too difficult to make
and will try to slowly get the other bits and pieces together or see to make some things myself .
That choke stove looks pretty darn good, nice work!!! I have the generator mounting bracket that you need, and a set of spark plug wire mounts, this is the last pieces of early 56 parts that I have left. I am selling my last early 56 car in January auctions and don't plan on doing another one, so these parts will be available. Now, with that being said, it will be a couple of weeks before I will be in Arizona where they are located and I will have to dig them out and check condition and price. As you know, this early stuff is not cheap.
