'56 dipstick
Old May 4, 2016 | 08:54 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Default '56 dipstick
Have a Bubba'd dipstick in my '56. Searched here but no help. All the parts houses list dipsticks for '57-'62. What is different about the '56? Can I use a '57-'62? Maybe a '55-'57 passenger car dipstick? Not worried about NCRS correctness, just having the correct oil level. The outer tube measures about 5-1/4" sticking out of the block.
Old May 4, 2016 | 09:06 AM
56early's Avatar
56early
is it first design right side or 2nd design left side if left side same as 57 pn 3722959
Old May 4, 2016 | 02:32 PM
davekp78's Avatar
davekp78
2nd design.
Thanks!
Correction: the tube is about 6 1/4" out of the block. Is this about right?
The Bubba'd dipstick measures 19 1/2". If I have the correct tube won't the '57 on dipstick (21 1/4") show me being overfilled?
Old May 4, 2016 | 06:07 PM
1955 copper's Avatar
1955 copper
2015 C1 of Year
Second design is the same as a 55 Corvette dip stick and tube ,which is only 55 and later 56 design. If you have a 265 with out a oil filter . Vary hard to locate try Tri-five.com. There forum is for 55 to 57 car only.
Old May 4, 2016 | 07:15 PM
emccomas's Avatar
emccomas
1956 Corvette (2nd design) Tube, Oil Level (upper) - 8 3/4 inches long - 3721928
1956 Corvette (2nd design) Tube, Oli Level (lower, inside case) - 7 3/4 inches long - 3837233
1956 Corvette (2nd design) Gauge, Oil Level - 21 9/16 inch under washer - 3722959
All info from 1929-1957 Chevrolet Parts and Accessories Catalog
Old May 5, 2016 | 08:50 AM
davekp78's Avatar
davekp78
Can you measure the length of the late '56 dip stick for me? Also, how far down for the full and add marks and the length of the tube above the block? I think I have the correct tube.
Thanks!
Old May 5, 2016 | 01:26 PM
emccomas's Avatar
emccomas
Thanks!
Who are you asking?
I have an absolutely original 56 passenger car dipstick. I cannot recall now if it is the same as the 2nd design Corvette dipstick.
I will look that up when I get home today.
Old May 5, 2016 | 02:15 PM
davekp78's Avatar
davekp78
Originally Posted by jv04
Who are you asking?
I was asking 1955 Copper, but if you could measure that would help.
Apparently the late '56 is unique-maybe a '55 is the same- but info is tough to find. I can see the dipstick tube is not the same as the '57 type.
Old May 5, 2016 | 02:30 PM
W Guy's Avatar
W Guy
The 1st design '56 stick is all by itself. p/n 3722960. Measures from cap to full 17 37/64". 18 27/64" to ADD mark
The 2nd design is the same for 56-57 Pass as well, p/n 3722959. Measures from cap to Full 19 31/64". To ADD: 20 7/16"
This is a 1st design stick
Old May 5, 2016 | 02:33 PM
1955 copper
2015 C1 of Year
[QUOTE=davekp78;1592148784]Can you measure the length of the late '56 dip stick for me? Also, how far down for the full and add marks and the length of the tube above the block? I think I have the correct tube.
Thanks![/
This is as good and close as I can do=
tube=6'1/2
stick=20'1/4 to the stop
To the full mark= 2'1/2
In 1957 it was a 283 engine
1955-56 Corvette was 265 engine the hole for the tube to fit in the engine was smaller,also making the stick narrow'er then a 283 engine
A 283 tube and stick will not work for a 265 engine
Does this help ? you do have a 265 engine?
Sorry VWGUY a car 57 will not work for a 265 ENGINE
Old May 5, 2016 | 02:52 PM
davekp78's Avatar
davekp78
Here is what I'm working with. Looks like it's too short. I have a 3722959 on order. When it comes, I guess I'll have to drain the oil, and reinstall 4 qts and see if everything works out. 4qts is right if I don't change the filter, right?
Old May 5, 2016 | 02:57 PM
davekp78's Avatar
davekp78
[QUOTE=1955 copper;1592151555]
Thanks![/
tube=6'1/2
Good info, thanks!
yes, my tube is about 6 1/2". Not sure about your "to the full mark".
I do have a 265.
Was in the process of writing my previous reply while this one came so the previous reply is OBE (overcome by events).
Thanks again!
Old May 5, 2016 | 03:30 PM
1955 copper
2015 C1 of Year
[QUOTE=davekp78;1592151760]
Good info, thanks!
I do have a 265.
Thanks again!
your 265 has a oil filter ? if so vary late
Old May 5, 2016 | 03:45 PM
davekp78's Avatar
davekp78
[QUOTE=1955 copper;1592151963]
May be a replacement but has the correct casting number-3720991.
One other thing I can do is take a ride up to Ecklers- they are local, and check their 56-57 passenger car dipstick listed in their Tri-5 catalog.
Old May 5, 2016 | 03:55 PM
W Guy's Avatar
W Guy
I was going by the parts book applications for the stick. I guess sometimes they are inaccurate.
Verne
Old May 5, 2016 | 04:03 PM
emccomas's Avatar
emccomas
I cannot find any reference to a 5 1/4 inch oil tube in the P&A catalog.
I am wondering if someone trimmed that tube down for some reason.
Old May 5, 2016 | 04:09 PM
emccomas's Avatar
emccomas
Duplicate - sorry
To '56 dipstick
Old May 5, 2016 | 04:36 PM
1955 copper
2015 C1 of Year
[QUOTE=W Guy;1592152120]
Verne
Over the years many older parts were and are superseded by # newer parts , many will work replacing the original part but not the original design looking part.
Old May 5, 2016 | 05:16 PM
W Guy's Avatar
W Guy
[QUOTE=1955 copper;1592152376]
I am aware of that. I should have looked at my '58 P&A instead of my '63 P&A which is right near me. Sorry
Old May 5, 2016 | 10:29 PM
davekp78's Avatar
davekp78
I had mis-measured. It actually is about 6-1/2" out of the block.
